Question On Oiling #2422849
12/23/17 10:19 PM
12/23/17 10:19 PM
MR_P_BODY Offline OP
I'm looking for a set of SB flat tappet lifters
with push rod oiling.. I see that Comp Cams
has a 2901-16 solid but I am wondering if it
works with push rod oiling.. I'm new to this
NON roller stuff.. last time I used a flat
tappet cam was in the early 70s... thanks for
the help
wave
Re: Question On Oiling [Re: MR_P_BODY] #2422883
12/23/17 11:23 PM
12/23/17 11:23 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
AMC lifters are the ones that oil thru the lifter/pushrod.
Re: Question On Oiling [Re: mopar dave] #2422899
12/23/17 11:51 PM
12/23/17 11:51 PM
I see that.. I found out that I want CC 801-16
thanks
wave
Re: Question On Oiling [Re: MR_P_BODY] #2422912
12/24/17 12:14 AM
12/24/17 12:14 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Be aware that the pushrod seat of the AMC lifters is higher then the mopar lifter....
Tony
70 AARCuda Vitamin C
Re: Question On Oiling [Re: 70AARcuda] #2422916
12/24/17 12:17 AM
12/24/17 12:17 AM
Does it still oil the push rods.. thanks
wave
Re: Question On Oiling [Re: MR_P_BODY] #2423039
12/24/17 11:50 AM
12/24/17 11:50 AM
The CC site says yes they both oil & 1.79" seat hite on the Mopar/AMC one & 1.63" on the std SB Mopar one. If they are the same ex for the hite (at least from the descrip it sounds like they are) then I would mockup with a junk lifter with the cup at those heights (I JB welded a hyd one for checking) & Hughes offers an adjustable one for checking (He may rent it out) & see which one gives the best valvetrain geometry. EDIT & I set (JBweld) the cup hite at whatever preload my setup has during mockup, maybe a bit OCD there but its my meticulousness
Re: Question On Oiling [Re: MR_P_BODY] #2423331
12/24/17 10:47 PM
12/24/17 10:47 PM
sioux falls, sd
10sec.dart Offline
10sec.dart  Offline
sioux falls, sd
Check out the lifters on Hughes web site, they are oil through,plus they have the edm hole, they were the ones I was going to run with my w9's, but I went 48' roller
