28x9 " tire under a dart #242264
03/03/09 07:43 PM
03/03/09 07:43 PM
somewhereintheswampsofjersey
1swingin Offline OP
1swingin  Offline OP
what do i need 2 do 2 get a 29 in. tire under my car?can i do it with the right wheel offset or do i need 2 relocate my springs. can i still run a stock fuel tank if i do? any pics or advice would be appreciated. iam a pretty good welder so iam not scared i just want 2 know what it takes!thanks guys! 9 in. width
"I aint here on buisness baby,Iam only here for fun"
Re: 29 " tire under a dart [Re: 1swingin] #242265
03/03/09 07:45 PM
03/03/09 07:45 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
first you will need to stretch the opening in front
Re: 29 " tire under a dart [Re: 1swingin] #242266
03/03/09 07:50 PM
03/03/09 07:50 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Width is where you run into problems, how wide is the tire?
Re: 29 " tire under a dart [Re: MoparJoe] #242267
03/03/09 07:56 PM
03/03/09 07:56 PM
1swingin Offline OP
1swingin  Offline OP
9 inch width if its possible!
Post deleted by Defbob [Re: 1swingin] #242268
03/03/09 08:14 PM
03/03/09 08:14 PM
Re: 29 " tire under a dart [Re: 1swingin] #242269
03/03/09 08:15 PM
03/03/09 08:15 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
What their saying is you will need to trim the
leading edge of your rear wheel wells a max of
2" (NHRA legal)and that will taper up into the
wheel opening.
You will probably also need to trim the wheel
lip or at least roll it in, sometimes this can
be done with a baseball bat rolled along the
tire to roll the lip in. Or have a body man
do it.
Of the "A" bodies the dart has the least
amount of clearance for bigger tires.
Phil Saran Parker, Colorado
Re: 29 " tire under a dart #242270
03/03/09 08:15 PM
03/03/09 08:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why not just mini-tub it so you can get a decent size tire under it?
Re: 29 " tire under a dart [Re: Quicktree] #242271
03/03/09 08:28 PM
03/03/09 08:28 PM
1swingin Offline OP
1swingin  Offline OP
i am pretty cheep and i just dont have time 2 do the mini tubs right now. i made a mistake also when i posted. i wanna get a 28x9 under this pile of crap. so what backspacing wheel do u suggest? thanks
Re: 29 " tire under a dart [Re: Quicktree] #242272
03/03/09 08:42 PM
03/03/09 08:42 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
Do it yourself.... you said in the another topic "60 foot times..." "i got the tools,i got the talent!!! "
Re: 29 " tire under a dart [Re: 1swingin] #242273
03/03/09 09:09 PM
03/03/09 09:09 PM
so cal
cmcgee123 Offline
cmcgee123  Offline
so cal
i fit a 29 11 under my 68 barracuda no problems at all
nitrous is like a really hot chick with an std you want to hit it but youre affraid of the outcome.
Re: 29 " tire under a dart [Re: cmcgee123] #242274
03/03/09 10:18 PM
03/03/09 10:18 PM
K
KOS Offline
KOS  Offline
K
youll need a 7"rim with 4.5BS guaranteed on a dart.on mine i can get goodyear 29x9s with the spring relo kit only.
Re: 29 " tire under a dart [Re: cmcgee123] #242275
03/03/09 10:24 PM
03/03/09 10:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We had a 28 x 9 MT slick under my sons Dart and it would rub in the front going thru the traps. Thats where you run into trouble if you run any taller then a 27" tire on a Dart. You can see by this pic that you have plenty of room in the rear of the tire so if you moved the rear back and inch the 28's would fit fine. We decided to run 26 x 9.5 Hoosier QTP tires (9" tread) because they fit with room to spare and work good with his 3.91's. But he could actually use more gear at the track as he was shifting his 400 at 6700. But its a street car and he dont want no more then the 3.91's because he drives it on the street. Ron
Re: 29 " tire under a dart [Re: 1swingin] #242276
03/03/09 10:29 PM
03/03/09 10:29 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I ran 9x28x15 Phoenix slicks on my 69 Dart. Relocated the springs in .75" and used a 8" wheel with 4.5" BS. I did have to grind the wheel opening lip some. The opening remained untouched. Jim
Re: 29 " tire under a dart [Re: rt66jim] #242277
03/04/09 02:07 AM
03/04/09 02:07 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
i ran a ET street 28x11.5 on mine for a while with no cutting of the front corner, no spring-relo. it was close though....
15 x 8 welds w/ 4.5 bs.
if you moved the springs in and ran more backspace, you wouldnt have to worry about that quarter lip
theres a long thread on this on bigblockdart thats stickied at the top.
Re: 29 " tire under a dart [Re: 493_DART] #242278
03/04/09 07:38 AM
03/04/09 07:38 AM
1swingin Offline OP
1swingin  Offline OP
thanks everyone 4 the info
Re: 29 " tire under a dart [Re: 1swingin] #242279
03/04/09 08:30 AM
03/04/09 08:30 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I run both a 275/60 and a 28 X 9 slick on my 69 Dart. The wheels are 15 X 8 with a 5.5" bs with the springs moved in 3/4" and the rear end moved back 1/2". I also had to trim the wheel well lips on both sides. The M/T ET Street Radials only have about 1/4" clearence on both sides and some times rub the springs.
Re: 29 " tire under a dart [Re: justinp61] #242280
03/04/09 02:12 PM
03/04/09 02:12 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
If you modify the wheel opening, the fender is supposed to have the edge folded (rolled) or a 1/4 inch rod welded to the edge to eliminate any sharp surfaces that could cut the tire.
Re: 29 " tire under a dart [Re: ProStDodge] #242281
03/04/09 05:56 PM
03/04/09 05:56 PM
Phoenix
jinxy Offline
jinxy  Offline
Phoenix
I run a 28x9 M/T et drag on a Centerline 8 1/2" wheel. The car is a stock body 1970 Dart. I have the 3/4" relo kit and the rear is spaced back 3/8" with aluminum blocks. Works great!
Re: 29 " tire under a dart [Re: jinxy] #2126822
08/06/16 11:43 PM
08/06/16 11:43 PM
jeff500 Offline
jeff500  Offline
I'm getting ready to move my rearend back 3/8 also and use aluminum spacer plates.where did you find the correct spring hanger studs that are 3/8 longer than stock?
Re: 29 " tire under a dart [Re: jeff500] #2126988
08/07/16 09:47 AM
08/07/16 09:47 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I used an E-body front spring mount on mine, it moved the wheel back enough to center the wheel in the wheel well . Mine is also mini tubbed but I have a 29 1/2 tall tire on there
