28x9 " tire under a dart
#242264
03/03/09 07:43 PM
03/03/09 07:43 PM
Posts: 521 somewhereintheswampsofjersey
1swingin
what do i need 2 do 2 get a 29 in. tire under my car?can i do it with the right wheel offset or do i need 2 relocate my springs. can i still run a stock fuel tank if i do? any pics or advice would be appreciated. iam a pretty good welder so iam not scared i just want 2 know what it takes!thanks guys! 9 in. width
"I aint here on buisness baby,Iam only here for fun"
Post deleted by Defbob
[Re: 1swingin]
#242268
03/03/09 08:14 PM
03/03/09 08:14 PM
Re: 29 " tire under a dart
[Re: 1swingin]
#242269
03/03/09 08:15 PM
03/03/09 08:15 PM
Posts: 396 California, USA
Phil Saran
California, USA
What their saying is you will need to trim the leading edge of your rear wheel wells a max of 2" (NHRA legal)and that will taper up into the wheel opening.
You will probably also need to trim the wheel lip or at least roll it in, sometimes this can be done with a baseball bat rolled along the tire to roll the lip in. Or have a body man do it.
Of the "A" bodies the dart has the least amount of clearance for bigger tires.
Phil Saran
Parker, Colorado
[Re: Quicktree]
#242271
03/03/09 08:28 PM
03/03/09 08:28 PM
1swingin
i am pretty cheep and i just dont have time 2 do the mini tubs right now. i made a mistake also when i posted. i wanna get a 28x9 under this pile of crap. so what backspacing wheel do u suggest? thanks
[Re: Quicktree]
#242272
03/03/09 08:42 PM
03/03/09 08:42 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
why not just mini-tub it so you can get a decent size tire under it?
Do it yourself.... you said in the another topic "60 foot times..." "i got the tools,i got the talent!!! "
[Re: 1swingin]
#242276
03/03/09 10:29 PM
03/03/09 10:29 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
I ran 9x28x15 Phoenix slicks on my 69 Dart. Relocated the springs in .75" and used a 8" wheel with 4.5" BS. I did have to grind the wheel opening lip some. The opening remained untouched. Jim
[Re: rt66jim]
#242277
03/04/09 02:07 AM
03/04/09 02:07 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
i ran a ET street 28x11.5 on mine for a while with no cutting of the front corner, no spring-relo. it was close though....
15 x 8 welds w/ 4.5 bs.
if you moved the springs in and ran more backspace, you wouldnt have to worry about that quarter lip
theres a long thread on this on bigblockdart thats stickied at the top.
