Re: Purple shaft cams back ordered forever? [Re: Cab_Burge] #2422204
12/22/17 04:07 AM
12/22/17 04:07 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I have pulled hi-tech modern dual pattern roller cams out of engines and went faster with 70s engineered racer brown flat tappets. All this so-called modern technology is just marketing to increase profits.
Re: Purple shaft cams back ordered forever? [Re: qwkmopardan] #2422217
12/22/17 05:42 AM
12/22/17 05:42 AM
[ twocents quote=qwkmopardan]I have pulled hi-tech modern dual pattern roller cams out of engines and went faster with 70s engineered racer brown flat tappets. All this so-called modern technology is just marketing to increase profits. [/quote]Me thinks your wrong on that tsk
Maybe you need a different brand of solid roller cams, I bought and used a bunch of Racer Browns flat tappet solid lifter cams in the late 1960 and early 1970 when he and Ed where still alive and running the business, once I switch to Cam Dynamics and later to Comp Cams solid flat tappet cams and then later to Comps solid Roller cams my race cars and my customers cars went faster and quicker up
But we did need to use a lot stiffer set of valve springs, matching keepers and retainers and better push rod to get the motors to RPM properly with the roller cams to work well work shruggy
What really surprised me was that the same roller cam specs at .050 compared to the identical flat tappet spec cams would fit in the motors better with out having to cut deeper valve reliefs in the old TRW/Speed Pro high compression race pistons we used back then on SB, BB and Hemi motors boogie
Those modern lobes where way better at making power than the old flat tappet lobes Racer designed and ground, especially the ones he designed and sold to Mopar for the Purple Shaft street program shruggy
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2422281
12/22/17 01:27 PM
12/22/17 01:27 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The bottom line is, not every build/combo will need or respond favorably to the fastest ramp, tightest lash, highest lift cam profile available.
There are many applications where the purple cams work just fine.
When they were $199 for a cam/lifter kit, they were a great bargain.
At $399+, they have priced themselves into obsolescence.
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2422304
12/22/17 02:09 PM
12/22/17 02:09 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Agree'd ^^^
Re: Purple shaft cams back ordered forever? [Re: Uncle Barry] #2422357
12/22/17 05:01 PM
12/22/17 05:01 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By Uncle Barry
I have absolutely no idea as to why anyone would want to use one of those things except for being "nostalgic". Soooo many better options out there.
Put simply? They work! ...or at least they did.
I loved the .528 solid in my '71 'Cuda. I also ran the .484 in a stock 440 in my '63 and it worked perfectly!
Nowdays, I have a hard time giving MP ANY money. They slap their name on someone else's product and mark it up waaay more than they used to! I refuse to run the Mopar Performance logo on anything I own.
'63 Dodge 330
11.19 @ 121 mph
Re: Purple shaft cams back ordered forever? [Re: GY3] #2422359
12/22/17 05:10 PM
12/22/17 05:10 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The nicest thing about these cams is not only did they work, but they didn’t require the spring pressures the cams need now. We ran this crap forever with zero maintenance.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2422362
12/22/17 05:33 PM
12/22/17 05:33 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Yes we did. Maximum power is not always the number one consideration. I used an old Cam Dynamics/Mopar .620-.640 Super Stock roller that they sold years ago. Made decent power, valve springs lived a couple of years, didn't break parts. Did everything I wanted it to do in that particular application.
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2422365
12/22/17 05:35 PM
12/22/17 05:35 PM
CA
crackedback Offline
crackedback  Offline
CA
That old 528 solid is one of the best cams. Just flat out works in is not too crazy for a hottish street car.
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2422367
12/22/17 05:43 PM
12/22/17 05:43 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Old junk from the seventy, no problem, I'm old junk from the fiftys.😎
Have a great day
Iowan
"obsolete is neat"
Re: Purple shaft cams back ordered forever? [Re: pittsburghracer] #2422368
12/22/17 05:44 PM
12/22/17 05:44 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Over 20 years on a PS...
All kinds of extreme conditions...
Zero 'maintenance'...
Cam;compression;converter since day one...
Re: Purple shaft cams back ordered forever? [Re: GY3] #2422424
12/22/17 07:30 PM
12/22/17 07:30 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
I didn't say they didn't work. I just wouldn't spend the money on one.
