codes on engine and transmission #2422030
12/21/17 09:39 PM
12/21/17 09:39 PM
Omaha
road Offline OP
road  Offline OP
Omaha
looking for some info on engine and transmission ID areas
gray pad is transmission. other is engine.
Re: codes on engine and transmission [Re: road] #2422039
12/21/17 09:53 PM
12/21/17 09:53 PM
AndyF Offline
AndyF  Offline
Little hard to read what you have there. The engine has a casting number, casting date, displacement and assembly date stamps as well as the VIN stamp. Use all of them to tell you what you have. The transmission has a part number, date stamp and sometimes a VIN. Once again, use all of the numbers to zero in on what you have.
Re: codes on engine and transmission [Re: road] #2422064
12/21/17 10:35 PM
12/21/17 10:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 0E trans if from a 1970 model year car built at LA, could be from a B or E-body.
The 0D block is also from a 1970 model, but from a C-body.
