Tapered axle drum removal? #2421212
12/19/17 11:35 PM
12/19/17 11:35 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I inherited a 67 Jeep Gladiator from my Dad. Its pretty nice but has been setting with little use since 2006. I tore the front brakes off easy enough. The rears appear to be tapered axle/hub like an early B-Body Mopar. I don't have a drum puller. The studs are swedged into the drum. What if I cut the studs off flush then punch them out. Slide the drum off and replace the studs. Open the swedged holes so the drums slide on. Anybody tried this?
Thanks Doug
Re: Tapered axle drum removal? [Re: dvw] #2421222
12/19/17 11:45 PM
12/19/17 11:45 PM
A727Tflite Offline
A727Tflite  Offline
Doug, you are welcome to use my puller. PM me and I can drop it off near CTC if you like. I'll be on the road tomorrow so no problem with getting it to you.
Re: Tapered axle drum removal? [Re: dvw] #2421227
12/19/17 11:48 PM
12/19/17 11:48 PM
Don't try that method, buy, rent or borrow the correct type drum puller and do it correctly up
You may need to add heat on the outer hub with tension on the hubs, especially to get the driver side off wrench hammer
There never easy, how much corrosion form road salts on this truck?
Good luck, don't cut corners on this tsk
Re: Tapered axle drum removal? [Re: dvw] #2421229
12/19/17 11:56 PM
12/19/17 11:56 PM
Minn
SportF Offline
SportF  Offline
Minn
The swedge is the problem if its the same as early B. The shoulder is swedged into a countersunk hole. I pressed them out once, and the swedge opened the hole up even bigger.
I doubt you could pound them out. I have always cut the head off, and pushed them out from the back.
I think you'll need a hub puller.
Re: Tapered axle drum removal? [Re: dvw] #2421233
12/20/17 12:00 AM
12/20/17 12:00 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
My buddy did that with his 64 B-body sort of.
He drove the old studs out with a BFH and and turned the swage down on the new studs in a lathe to the size of the holes in the drum, just a few thou so they fit tight with no movement.
He had the correct puller and ruined the end of the axle trying to remove a particularly stubborn hub.
Never again he said.
Kevin
Re: Tapered axle drum removal? [Re: Twostick] #2421239
12/20/17 12:21 AM
12/20/17 12:21 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Kevin
That was my experience as well. I just change out the rear axle assembly for something more modern. That solves the brake drum removal problem on that vehicle for good. Gene
Re: Tapered axle drum removal? [Re: poorboy] #2421241
12/20/17 12:24 AM
12/20/17 12:24 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
An A body 8 3/4 will bolt into a '68, '69, and maybe '70 AMX and Javelin. I've done it with my '68 AMX. Take measurements of whatever AMC car/truck/Jeep and check with Mopar experts on the closest pad measurements to see what might fit.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Tapered axle drum removal? [Re: dvw] #2421338
12/20/17 08:22 AM
12/20/17 08:22 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
The paint isnt special, but his thing is way to original to cut. I can't believe I'm saying that, I modify everything I own. Anyway this is a rust free 18,000 mile California truck with the dealer installed dump mechanism for the box.
Doug
Re: Tapered axle drum removal? [Re: dvw] #2421352
12/20/17 09:53 AM
12/20/17 09:53 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree get the tool.I used mine a lot when we had the old Mopars.Never messed up an axel end.Thats why you leave the big nut on loose when you pull the drum.I probally did a few hundred between when we owened them at work etc.You do have to have the puller centered also.Often thought of selling my tool as I dont have any cars touse it on now and Im retired.Rocky
Chrysler Firepower
Re: Tapered axle drum removal? [Re: dvw] #2421399
12/20/17 12:38 PM
12/20/17 12:38 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Your plan will work if you can't find a puller. Using the puller IS the correct way to do this, however.... if you choose to cut the studs do the following:
Cut the studs off as close to flush as possible. Then drill a 3/16" - 1/4" hole in the center of each stud approximately 1/2" deep. This will allow the swedged area of the stud to collapse on itself and not damage the hub when you force it out. If you don't drill this hole it WILL damage the hub and you'll have to pull it anyway to drill a larger hole and then find studs with a larger knurl diameter. Simply drilling the hole will solve this problem.
Once you have the drum off rebuild the rear brakes while you're in there and then replace the studs. Drill the holes in the drum to the size required to fit over the knurl area of the new studs and you're done. This will allow you to simply slip the hubs off whenever you need to service the rear brakes as well.
Like I said, this is NOT the best way to do this. Removing the hub with a puller and pressing the studs out (after drilling the hole) is the best way. But this will work if you're careful and take your time.
Good luck.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Tapered axle drum removal? [Re: dvw] #2421471
12/20/17 03:38 PM
12/20/17 03:38 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Just use a swedge removal cutter if you decide to pop the studs out. They are available from several sources. I make my own.
example:
https://goodson.com/products/swedge-tools
Re: Tapered axle drum removal? [Re: dvw] #2421492
12/20/17 04:58 PM
12/20/17 04:58 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Originally Posted By dvw
Doug
What's the pink in the pic???
Re: Tapered axle drum removal? [Re: SportF] #2421526
12/20/17 06:13 PM
12/20/17 06:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've been preaching this for years but nobody listens.
Re: Tapered axle drum removal? [Re: RSNOMO] #2421545
12/20/17 07:14 PM
12/20/17 07:14 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Doug
My wife's car. Yes I cut it up a matching number 73 340 4 speed Ralley. Now a 360 4 speed fake R/T. She wanted a Panther Pink 4 speed Challenger. The Jeep will be her "garden truck". No more mulch in the trunk of the Challenger.
Doug
