motor plate questions
#242124
03/03/09 05:30 PM
03/03/09 05:30 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
is there a HP point where you should run a motor plate? my engine seems to be twisting too much lately and wondering about buying new mounts or plate it
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: motor plate questions
[Re: sixpackgut]
#242125
03/03/09 05:41 PM
03/03/09 05:41 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
How about solid mounts or a limiter?
[Re: sixpackgut]
#242126
03/03/09 06:50 PM
03/03/09 06:50 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I'm not sure at what HP level one is mandatory, but I'd say around 600-650 hp it's a good idea. Once you use a plate you'll never want to use stock mounts again. At your power level I do think you need one. CHIP
[Re: sixpackgut]
#242127
03/03/09 06:53 PM
03/03/09 06:53 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
Go with the AR Engineering one that AndyF makes You will not find a better one PERIOD!!! Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 70blackfish]
#242131
03/03/09 08:12 PM
03/03/09 08:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I was wondering the same thing, I have seen the motor mount ears on the block broken off.
I guess you could install the motor plate with the motor sitting on the motor mounts for locating it, then remove the mounts
The ears break off usually because they went to the solid mounts and no limiters... the ears cant take the fore and aft movement of the engine. Even with a motor plate it is advised that you use limiters to control the fore and aft movement
[Re: MR_P_BODY]
#242132
03/03/09 08:24 PM
03/03/09 08:24 PM
another vote for AndyF motorplate but my 581 hemi is still using stock motor mounts with 850 hp with no problems with a torque strap.
#242133
03/03/09 11:40 PM
03/03/09 11:40 PM
sixpackgut
Charleston
Ari, thanks for the great pictures. i think i want to put on in. good point on the mount pulling on the cylinders too. it just seems like the engine is about to rotate around and scrape my six pack off the ground that plate looks nice and thick too
[Re: schwep]
#242141
03/04/09 06:43 PM
03/04/09 06:43 PM
MR_P_BODY
I have 2 threaded rods(1 on each side) attached to the mount ears then to the chassis, but I'm changing them this spring to a nicer set of heim ends on a rod.... mine look ugly now EDIT Some of the guys have been mounting the limiters on the 2 ears on the trans to the frame rails/chassis
[Re: sixpackgut]
#242142
03/04/09 06:54 PM
03/04/09 06:54 PM
an8sec70cuda
I have a poly trans mount, no problems.
For the fore/aft limiter I used a Comp Engineering kit and attached one end of the rod to the trans crossmember w/ a 90* bracket and then attached the other end to the transmission case at the rear passenger's side corner just above the pan rail. CHIP
[Re: Quicktree]
#242144
03/04/09 07:26 PM
03/04/09 07:26 PM
MR_P_BODY
Clamps.... its a little different Tony, they flex big time and they are right up against the rearend via a coupling
[Re: Quicktree]
#242145
03/04/09 07:28 PM
03/04/09 07:28 PM
I use a set of old school elephant ears with a solid welded passenger side stock mount. The trans mount is poly. This set up is low buck,strong,and solved my external oil line clearance problem. I run 10.90-11.00 @ about 660 hp.
[Re: MR_P_BODY]
#242146
03/04/09 08:26 PM
03/04/09 08:26 PM
Quicktree
ok lets scale down to a super comp dragster, same deal. they are held on the front by 2 aircraft type water hose clamps and they are not held against the rear end. they do have a coupler but it's loose fit. and with all the flexing you say wouldn't that make it worse? my point is the heavy duty front motor plates are not needed imo.
[Re: MR_P_BODY]
#242148
03/04/09 08:40 PM
03/04/09 08:40 PM
Quicktree
If you wheel stand and run a 1/4" plate and come down hard.... it WILL buckle.... as me. I stepped up to a 3/8" plate with limiters
so will your oil pan and a whole bunch of other stuff
[Re: Quicktree]
#242151
03/04/09 09:26 PM
03/04/09 09:26 PM
sixpackgut
Charleston
Tony, what exactly is your point? i like the heavier plate because of the 1.cutouts 2. they are made by a member here 3. they are sold by a sponsor here 4. i dont have any extra hose clamps to use as motor mounts
[Re: sixpackgut]
#242152
03/04/09 09:43 PM
03/04/09 09:43 PM
Quicktree
nothing wrong with it, I don't like the triangle cut outs on that one but it's not going to hurt anything. go for it.
[Re: hemi-itis]
#242154
03/04/09 10:52 PM
03/04/09 10:52 PM
Quicktree
I don't care for the triangles.These go with my weld wheels.I bought mine from V & V machine in Wappingers Falls NY.
that looks much better to me, but thats just my opinion.
[Re: nhramark]
#242158
03/05/09 12:50 PM
03/05/09 12:50 PM
sixpackgut
Charleston
Hey I didn't want to horn in, but Andy has not replied. I can make your motor plate and we will "customize" it for you.(holes, triangles, solid, we can even put a pentestar in it if you want)
PM me if you are interested.
can you post pics of some plates? i would like to see some different ones
[Re: sixpackgut]
#242159
03/05/09 10:46 PM
03/05/09 10:46 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
Here is a pic of our new 5.7 Hemi 3/8" motorplate. www.aeicnc.comWebsite will be updated soon, click the automotive tab.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#242160
03/05/09 11:04 PM
03/05/09 11:04 PM
nhramark
Wheels up, MO
Here's a pic from the other side that I didn't botch while re-sizing.
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#242161
03/05/09 11:06 PM
03/05/09 11:06 PM
Posts: 5,618 long island NY
Ari440
long island NY
www.aeicnc.com
will you be able to make 1/4 to 3/8 valvecover spacers for bigblock mopars ?
1.39 9.85 - 137 mph
[Re: sixpackgut]
#242166
09/23/10 02:54 AM
09/23/10 02:54 AM
Posts: 399 Wisconsin
raleye72
Wisconsin
Hi, I have a 72 Charger that i'm running 10.60's with. I've done a few upgrades and should be in the 10.20's to 10.teens. I was looking at doing the motor plate upgrade as well. How can I get in touch with Andy at AE Engineering. I tried looking it up on my search engine and can't find it. Also would be interested in NHRA Mark's plate with the pentastars on it. Could you send me your contact info Mark? Please email me at raleye72@hotmail.com. Thanks Jeremy
[Re: raleye72]
#242167
09/23/10 04:45 AM
09/23/10 04:45 AM
Posts: 6,295 U.S.
moparniac
U.S.
I have solid motor mounts and poly tranny mount! I was thinking about some strap also ( side to side) cause my snout bars come in right where a motor plate would hook up to! EDIT: I just realized one of my proparts headers tubes is RIGHT under the dr side snout bar touching it keeping the engine from twisting side to side!
Mopar Performance
[Re: moparniac]
#242168
09/23/10 08:30 AM
09/23/10 08:30 AM
an8sec70cuda
Sledge...That's why a lot of people attach the plate to the snout bars by welding tabs on the bars.
I like motorplates w/ NO holes in them whatsoever. The one w/ the triangles cut out would be a pain if you had a lot of stuff to mount to it...like a vacuum pump, coil, catch can, oil filter adapter, etc. Having it solid makes it much easier to position your stuff on it right where you need it.
[Re: sixpackgut]
#242169
09/23/10 09:33 AM
09/23/10 09:33 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Ray I know they dont look like stock, and cause some headaches as far as pulley alignment, alt setups. But once you go that route, and see what a easy setup it is, and working on it, you will be asking your self why you hadnt done it before.. And I make them my self. I just used some 1/4 steel and swiss cheesed them to lightning them, and give them more of a custom look. Just used a couple water pump gaskets as temp-lets and went to town. I fired up the Torch and cut the holes, they look like they were cut with a hole saw for the most. I like doing these kind of parts my self, and it save's me a C-note too Not a great pic, and have since moved the fuel isolator but you get the idea.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: nosboy]
#242171
09/23/10 11:09 AM
09/23/10 11:09 AM
MR_P_BODY
I firmly believe in motor plates.. FRONT AND MIDPLATE with a POLY trans mount.. I've been told about rubber trans mounts contributing to cracked trans cases because of it's ability to FLEX... I have a World products wedge block that is somewhat "stronger" than an stock 440 wedge block,, so I am not concerned with twisting or torqueing like some previous posts... I also think there is NO NEED for a 3/8 plate if you are going to run a MIDPLATE.. A 900HP engine with a 3/8 front plate and NOTHING between the engine and trans is a CATASTROPHE waiting to happen.. ESPECIALLY with a rubber trans mount.. There is FIVE FEET or more between the FRONT MOUNT and the TRANS MOUNT !!!! NOT A GOOD IDEA.... A 600Hp engine could get away with a front plate ( Providing it's 6061 T6,or better 3/8 thick or BETTER ) and a poly trans mount,, but,, I wouldn't try it with a stroker motor !!!
I disagree with you... if you dont use a limiter you are asking a vertical plate to carry the launch load of about 700 lbs(static) ... take a alum plate and set it on a pair of blocks that are at the same width as the outer mount points... now get up on it in the center and bounce(and I dont think you weigh anything near the engine and trans weight) you will see how much it bows or bends.... now sure this will depend on how hard the car launches on how much it will move.... also especially if you use a front and mid plate you want some movement on the trans mount either with a stock or poly mount... you cant acount for chassis flex if its a solid mount... remember the old math class... 2 points are a line but when the 3rd point is induced its not always a straight line and now induce chassis flex that 3rd point is trying to move
[Re: MR_P_BODY]
#242173
09/23/10 09:37 PM
09/23/10 09:37 PM
Posts: 205 Chicago,Illinois
nosboy
Chicago,Illinois
Let me try and explain... An aluminum front plate , lets say 5/16 of 6061 T6 and a midplate made of relatively mild steel and a POLY trans mount on a 900 HP backhalved Challenger, there is NO NEED for limiter straps.. providing you have a STOUT block ( world castings) and a 727 trans with a TRUCK tailshaft housing.. with a POLY mount... Tightened up properly, it shouldn't twist up much at all.. The whole thing twisting up as a unit (including whatever the "body does") is MINIMAL ,,to say the least... There's about .004 clearance for the "basically body fit" 3/8 hold down bolts,,, and if it WAS TWISTING UP, I would lose the almost PERFECT line up when removing and reinstalling the motor plates... I'm NOT a chassis builder by any means,, I just have mine setup that way and it works FINE without any limiters... I think,, in MY SETUP,,, the limiters are a waste of time and money...
[Re: nosboy]
#242175
09/23/10 11:42 PM
09/23/10 11:42 PM
nhramark
Wheels up, MO
nosboy - you and Pbody are talking about 2 different things.... Raff is talking about a fore/aft limiter to prevent forward and rearward movement of the motor. I believe you are talking about limiter straps to stop the motor from torquing over side to side.
9.100 @ 150 mph
5.780 @ 120 mph
