727 BB 8 bolt Flexplate options #2421083
12/19/17 07:42 PM
12/19/17 07:42 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
What are my options for 727 torqueflite BB 8 Bolt flexplate besides B & M?
I see Mopar Performance are no longer made.
Are B & M a better quality than MP?
Re: 727 BB 8 bolt Flexplate options [Re: Sammy] #2421092
12/19/17 08:08 PM
12/19/17 08:08 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I broke a Mopar one around the outer ears. Never had an issue with the B&M it was replaced with. Both were new when installed.
Doug
Re: 727 BB 8 bolt Flexplate options [Re: Sammy] #2421094
12/19/17 08:09 PM
12/19/17 08:09 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Never seen or heard of an issue with a B&M flex plate. I've had one 20 plus years in my 10 second 4000lbs GTX. My Low 9 second Hemi GTX has one but have yet to run it.
Re: 727 BB 8 bolt Flexplate options [Re: Sammy] #2421097
12/19/17 08:14 PM
12/19/17 08:14 PM
Staten Island, NY
RO23dave Offline
RO23dave  Offline
Staten Island, NY
I had a bad vibration with mine, I knew that was the cause of vibration cause it was the only thing I had changed. Took it off & replaced it with a mopar unit, and no more vibration. Gave the B&M unit away. Dave ss/ea #1355 fury
Re: 727 BB 8 bolt Flexplate options [Re: Sammy] #2421126
12/19/17 09:13 PM
12/19/17 09:13 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Anyone use this TCI? It's not SFI. Does that mean its not as strong as a SFI piece?
https://www.summitracing.com/parts/tci-145300
Re: 727 BB 8 bolt Flexplate options [Re: Sammy] #2421128
12/19/17 09:25 PM
12/19/17 09:25 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Had one like that, it cracked. Get an sfi one.
Re: 727 BB 8 bolt Flexplate options [Re: rickraw] #2421138
12/19/17 09:50 PM
12/19/17 09:50 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
B&M here. Zero issues.
'63 Dodge 330
11.19 @ 121 mph
Re: 727 BB 8 bolt Flexplate options [Re: Sammy] #2421213
12/19/17 11:38 PM
12/19/17 11:38 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Had one in my Cuda for 10 yrs no issues. Have had one in my 4000lb wagon going on 5 yrs no vibrations or issues.
Ok
Re: 727 BB 8 bolt Flexplate options [Re: Sammy] #2421228
12/19/17 11:55 PM
12/19/17 11:55 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
I think I have a 8 bolt b&m that I bought and never used but its sfi might not be good because of age. I got it cheap I will sell it for 30 dollars I got it for. its never been bolted on nothing.
Re: 727 BB 8 bolt Flexplate options [Re: Sammy] #2421317
12/20/17 03:17 AM
12/20/17 03:17 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
B&M here as well.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 727 BB 8 bolt Flexplate options [Re: hemi-itis] #2421324
12/20/17 03:51 AM
12/20/17 03:51 AM
I've used a ton of OEM street hemi in my race cars as well as several "Mopar" SFI tagged race ones up , I've never hurt one of either type or know any racer out here that has that had a decent converter to start with work I have seen them cracked but we also found out why, like a missing oil pump drive bushing or cracked or worn out bushing shruggy
I know several local racers that bought and used the B&M 6 bolt plates that had problems with all of the B&M they used work
Not so with the Mopar brand race 6 bolt flexplates with the large (7/16 diameter) race converter bolts up
Re: 727 BB 8 bolt Flexplate options [Re: Sammy] #2449607
02/10/18 05:05 PM
02/10/18 05:05 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Finally installed the B & M Flexplate and I am very pleased with the quality of it.
Curious, but it seems that the bolt holes to the converter are a little closer to the engine giving me a little more clearance to the converter but I could be wrong. Comparing this to the MP 8 hole flexplate.
Re: 727 BB 8 bolt Flexplate options [Re: Sammy] #2449620
02/10/18 05:21 PM
02/10/18 05:21 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I've used B&M, MP and a stock Hemi, no problems with any of them.
Have a great day
Iowan
"obsolete is neat"
Re: 727 BB 8 bolt Flexplate options [Re: Sammy] #2449688
02/10/18 07:09 PM
02/10/18 07:09 PM
New York
polyspheric Offline
polyspheric  Offline
New York
IIRC the 8 bolt pattern is actually the factory *-1962 (B/RB, early poly, Gen-1 hemi) stock flange.
Didn't there used to be 2 different 8 bolt flex plates, depending on the converter bolt size?
Boffin Emeritus
Re: 727 BB 8 bolt Flexplate options [Re: Sammy] #2449778
02/10/18 09:34 PM
02/10/18 09:34 PM
A727Tflite Online content
A727Tflite  Online Content
One 8 bolt flex plate for production - came out with Gen II Hemi. Same pattern between race and street hemi.
Before that there was I believe an 8 "bolt" design - but had no flex plate.
The converter had studs that engaged the crank holes, held to the crank with nuts.
There are two different 6 bolt flex plates - depending on converter bolt size. But the large converter bolt plate was a Direct Connection - I don't recall us ever offering a large drive lug bolt converter for a six bolt crank in production.
Re: 727 BB 8 bolt Flexplate options [Re: A727Tflite] #2449818
02/10/18 10:25 PM
02/10/18 10:25 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
8 bolt oem number was 2466715.
Re: 727 BB 8 bolt Flexplate options [Re: A727Tflite] #2449829
02/10/18 10:48 PM
02/10/18 10:48 PM
How about 1962 to 1964 M.W., my 1963 Belevedere 415 HP M.W. had one in it in 1971 shruggy
