1970 Super Bee Manual Steering Box I.D.
#2418433
12/14/17 12:54 PM
12/14/17 12:54 PM
Posts: 2,367 Wheatfield, NY
Cuda340
Wheatfield, NY
Is this steering box correct for a 1970 B-Body? I believe it to be original to the car but I want to double check. Can anyone decipher the numbers? Does the pitman arm look correct?
Re: 1970 Super Bee Manual Steering Box I.D.
[Re: Cuda340]
#2420452
12/18/17 05:47 PM
12/18/17 05:47 PM
Cuda340
Wheatfield, NY
I just called Firmfeel to see if they could decipher the numbers. He was very nice and did say that the part number ending in 49 - 2537349-2 is a bearing box, not a bushing box so it is probably the one from my car. A-bodies got the bushing box. That's a start.
[Re: Cuda340]
#2420629
12/18/17 10:09 PM
12/18/17 10:09 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Thanks for the help Morty, but what do you make of my number on my box? any input? I don't know what it means. I have 11 cars but only one is manual steering and that is the 70 Bee pictured. Dan is the resident date code guy.
[Re: Morty426]
#2420821
12/19/17 04:39 AM
12/19/17 04:39 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
I'll have to check some examples but ..... if E7029G = Wed. 7/2/69 then E06024G = Tue. 6/2/74
[Re: 6bblgt]
#2420832
12/19/17 06:38 AM
12/19/17 06:38 AM
Morty426
Sacramento CA
I'll have to check some examples but ..... if E7029G = Wed. 7/2/69 then E06024G = Tue. 6/7/74 Dan - I think you have a little typo E7029G = Wed. 7/2/69 then E06024G = Tue. 6/ 2/74
[Re: Morty426]
#2420939
12/19/17 02:44 PM
12/19/17 02:44 PM
Cuda340
Wheatfield, NY
I'll have to check some examples but ..... if E7029G = Wed. 7/2/69 then E06024G = Tue. 6/7/74 Dan - I think you have a little typo E7029G = Wed. 7/2/69 then E06024G = Tue. 6/ 2/74 I am not completely sold that this is a 74 box. I am leaning towards the "E" meaning 1969. Wonder what the "G" means? It may be the 7029 box assembled? or the 06024 box assembled?
[Re: Morty426]
#2421432
12/20/17 01:54 PM
12/20/17 01:54 PM
Cuda340
Wheatfield, NY
Here is the box in my other sixpack 70 Bee. This is a 802 SPD car that was probably built around 8/12/69. The car has been off the road since 1973
If this is a date good I would guess it is
7 - July 02 - 2nd 9 - 1969
That can also decode to 7/29/69
[Re: Cuda340]
#2421629
12/20/17 10:32 PM
12/20/17 10:32 PM
6bblgt
Las Vegas, NV
with help from the '70 Parts Catalogmanual steering box housingpart # 2537 347 6-cyl A-bodies (#2537 3 ?? casting) bushing part # 2537 346 B & E-bodies and 8-cyl A-bodies (#2537 349 casting) bearing first digit E, F, G = model year '69, '70, '71 & the G, H, J = revision numbers? here are a couple more unknown origins
[Re: Morty426]
#2421823
12/21/17 01:06 PM
12/21/17 01:06 PM
Cuda340
Wheatfield, NY
Hello Morty, Thank you for taking the time to post the pic of the stamped numbers on the steering box. Would it be too much trouble to clean the side of the box and get a picture of the casting number and maybe a pic of the pitman arm to see if it similar to the one that is attached to my box? If Dan's info from the 1970 parts catalog is correct them it seems I have a A-body V-8 bearing box. Are the boxes the same angle and such? Do they interchange between A,B &E? Dan, Thank you for taking the time to respond to my threads!
[Re: 6bblgt]
#2421965
12/21/17 06:46 PM
12/21/17 06:46 PM
Cuda340
Wheatfield, NY
the bearing box cast#2537349 & part#2537346 is correct for your '70 Super Bee (all E/B-bodies & V8 A-bodies) Awesome! Thanks for the clarification. I must have misinterpreted it. Have a great holiday Dan!
