1970 Super Bee Manual Steering Box I.D. #2418433
12/14/17 12:54 PM
12/14/17 12:54 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Is this steering box correct for a 1970 B-Body? I believe it to be original to the car but I want to double check. Can anyone decipher the numbers? Does the pitman arm look correct?
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Cuda340] #2419284
12/16/17 12:19 AM
12/16/17 12:19 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Here is the box in my other sixpack 70 Bee. This is a 802 SPD car that was probably built around 8/12/69. The car has been off the road since 1973
If this is a date good I would guess it is
7 - July
02 - 2nd
9 - 1969
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Morty426] #2420332
12/18/17 02:22 PM
12/18/17 02:22 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Thanks for the help Morty, but what do you make of my number on my box? any input?
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Cuda340] #2420452
12/18/17 05:47 PM
12/18/17 05:47 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
I just called Firmfeel to see if they could decipher the numbers. He was very nice and did say that the part number ending in 49 - 2537349-2 is a bearing box, not a bushing box so it is probably the one from my car. A-bodies got the bushing box. That's a start.
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Cuda340] #2420629
12/18/17 10:09 PM
12/18/17 10:09 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I don't know what it means. I have 11 cars but only one is manual steering and that is the 70 Bee pictured.
Dan is the resident date code guy.
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Morty426] #2420821
12/19/17 04:39 AM
12/19/17 04:39 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I'll have to check some examples but .....
if
E7029G = Wed. 7/2/69
then
E06024G = Tue. 6/2/74
shruggy
Re: 1970 Super Bee Manual Steering Box I.D. [Re: 6bblgt] #2420832
12/19/17 06:38 AM
12/19/17 06:38 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
if
then
E06024G = Tue. 6/7/74
shruggy
Dan - I think you have a little typo
then
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Morty426] #2420939
12/19/17 02:44 PM
12/19/17 02:44 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
if
then
shruggy
then
I am not completely sold that this is a 74 box. I am leaning towards the "E" meaning 1969. Wonder what the "G" means? It may be the 7029 box assembled? or the 06024 box assembled?
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Cuda340] #2421106
12/19/17 08:37 PM
12/19/17 08:37 PM
NE Ohio
Govierjr. Offline
Govierjr.  Offline
NE Ohio
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Cuda340] #2421130
12/19/17 09:27 PM
12/19/17 09:27 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 Valiant, 403 SPD with a March door sticker.
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Cuda340] #2421410
12/20/17 01:06 PM
12/20/17 01:06 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
So according to the other thread, that is posted above by Govierjr (nice lol) my box would decode to June 24th 1969,79, or 89.
Would a June 24th 1969 be a good date for a SPD of 9/29/69?
I am good with that....
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Cuda340] #2421413
12/20/17 01:13 PM
12/20/17 01:13 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
WAG
Day -Year
TO724R � 72nd day of 1974
Year - Day
F0313G � 1970 313th day
Mon � Day Year
F11012R � Nov 1, 1972-82
E06019G � Jun 19, 1969-79-89
This was from the other thread.
Good Info
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Morty426] #2421432
12/20/17 01:54 PM
12/20/17 01:54 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
7 - July
02 - 2nd
9 - 1969
That can also decode to 7/29/69
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Cuda340] #2421629
12/20/17 10:32 PM
12/20/17 10:32 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
with help from the '70 Parts Catalog
manual steering box housing
part # 2537 347 6-cyl A-bodies (#2537 3?? casting) bushing
part # 2537 346 B & E-bodies and 8-cyl A-bodies (#2537 349 casting) bearing
first digit E, F, G = model year '69, '70, '71 shruggy & the G, H, J = revision numbers?
here are a couple more unknown origins scope
Re: 1970 Super Bee Manual Steering Box I.D. [Re: Morty426] #2421823
12/21/17 01:06 PM
12/21/17 01:06 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
7 - July
02 - 2nd
9 - 1969
Hello Morty,
Thank you for taking the time to post the pic of the stamped numbers on the steering box. Would it be too much trouble to clean the side of the box and get a picture of the casting number and maybe a pic of the pitman arm to see if it similar to the one that is attached to my box?
If Dan's info from the 1970 parts catalog is correct them it seems I have a A-body V-8 bearing box. Are the boxes the same angle and such? Do they interchange between A,B &E?
Dan,
Thank you for taking the time to respond to my threads!
Re: 1970 Super Bee Manual Steering Box I.D. [Re: 6bblgt] #2421870
12/21/17 03:33 PM
12/21/17 03:33 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the bearing box cast#2537349 & part#2537346 is correct for your '70 Super Bee (all E/B-bodies & V8 A-bodies)
Re: 1970 Super Bee Manual Steering Box I.D. [Re: 6bblgt] #2421965
12/21/17 06:46 PM
12/21/17 06:46 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Awesome! Thanks for the clarification. I must have misinterpreted it.
Have a great holiday Dan!
