2008 ram 5.7 auto. shifter problem #2408598
11/25/17 10:50 AM
11/25/17 10:50 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
I been expermince problem with my shifter on a cold morning..I have to played with it to get it to go into gear after it warms up no problem.. well ever once in awhile.. do i need to replace the brake switch to correct this problem?
thank you for any info guys!
Re: 2008 ram 5.7 auto. shifter problem [Re: BigTerry] #2408858
11/25/17 10:57 PM
11/25/17 10:57 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
next time try pushing the brake pedal firmly then move the gearshift. But then the switch could be out of adjustment. They might try and tell you it's not adjustable but you can. Sometimes when driver exits they bump the back side of the pedal and wack it out of adjustment.
Re: 2008 ram 5.7 auto. shifter problem [Re: BigTerry] #2409580
11/27/17 01:22 PM
11/27/17 01:22 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Go into gear or to get it out of park?
Did the '08 have the same problem as my '06 of the bushings in the brake pedal mount breaking apart and allowing the brake pedal to move side-to-side? work I noticed that sometimes if I wasn't pushing straight down on the brake pedal that the brake lights did not come on. blush
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 2008 ram 5.7 auto. shifter problem [Re: I_bleed_MOPAR] #2417240
12/12/17 10:38 AM
12/12/17 10:38 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
mainly getting it out of park!
Re: 2008 ram 5.7 auto. shifter problem [Re: BigTerry] #2419487
12/16/17 03:27 PM
12/16/17 03:27 PM
Buford, GA
Buford, GA
If you haven't already figured it out, I would grab the brake pedal and see if it moves side-to-side. If it does, that may be the problem.
Tim
'71 Charger 383/727
Re: 2008 ram 5.7 auto. shifter problem [Re: I_bleed_MOPAR] #2419919
12/17/17 05:12 PM
12/17/17 05:12 PM
North Central USA (MN-WI area)
MuscleMopars Offline
I'm having the same problem with my 2005 3500 dually. I can barely get it out of park no matter if it's warm or cold!
Thanks,
Eric
email eric@musclemopars.com
715-426-HEMI (Shop)
612-669-CARS (Cell and Texts)
Go to my Moparts "Profile" to see my web site
