Fast EZ-EFI amperage requirements? #2418611
12/14/17 07:27 PM
12/14/17 07:27 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I'm installing an EZ-EFI 2.0 on my 1970 Dodge Dart. Trying to figure out if I need to upgrade my alternator. Can anyone tell me the amperage draw of the EZ-EFI 2.0?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Fast EZ-EFI amperage requirements? [Re: MadMatt] #2418754
12/14/17 11:32 PM
12/14/17 11:32 PM
IN
ahy Offline
ahy  Offline
IN
I'll guess the ECU itself is in the 5-10 amp range. In addition you will need an electric fuel pump that draws 10-25 amps. Total added draw 20-35 amps.
EFI systems do not like voltage variations. The factory system from 70 already discharged at idle with no added loads. With added load it would be bad. As absolute minimum you need a later factory squareback (78 amps) or something similar or better from Powermaster or Tuff Stuff. It will bolt right in. In addition, you need to bypass the ammeter and bulkhead connector with charge current to handle the higher load.
I ran an XFI system with a higher rated square back and it was marginal at best with big fuel pump. I upgraded to a 105 amp alternator and much better.
Bottom line you need to upgrade from the 70's system for EFI.
Re: Fast EZ-EFI amperage requirements? [Re: MadMatt] #2418761
12/14/17 11:44 PM
12/14/17 11:44 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
What engine? A delco 12si which can be had cheaply at 94A is an easy swap on a small block at least. They charge well at idle.
The picture is from my friend's car. But mine also has a 12si and I have a Megasquirt 3 Pro, 340lph Aeromotive fuel pump, and contour fans and the 78a version is still keeping up well.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Fast EZ-EFI amperage requirements? [Re: goldduster318] #2418902
12/15/17 10:21 AM
12/15/17 10:21 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Originally Posted By goldduster318
...Megasquirt 3 Pro, 340lph Aeromotive fuel pump, and contour fans and the 78a version is still keeping up well.
For what it's worth. I have an inductive ammeter setup on my MS3 and with the same fuel pump, ECU and fans, I can only pull about 35a once the fans are running. With headlights and the blower on high I hit about 60a. Not a problem for my charging system, though.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Fast EZ-EFI amperage requirements? [Re: GoodysGotaCuda] #2419094
12/15/17 04:56 PM
12/15/17 04:56 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
[/quote]
For what it's worth. I have an inductive ammeter setup on my MS3 and with the same fuel pump, ECU and fans, I can only pull about 35a once the fans are running. With headlights and the blower on high I hit about 60a. Not a problem for my charging system, though. [/quote]
Thanks! That's really helpful.
Re: Fast EZ-EFI amperage requirements? [Re: GoodysGotaCuda] #2419171
12/15/17 08:54 PM
12/15/17 08:54 PM
Lake Orion, MI
Lake Orion, MI
Yeah, This is probably why it can keep up. There isn't an original style mopar alternator that charges anywhere near 40A at idle, I think the SI will do about 50A at idle with my curb speed and pulley ratio.
The 94A is probably a better choice but this one has been on the car for almost 6 years already
Re: Fast EZ-EFI amperage requirements? [Re: MadMatt] #2419633
12/16/17 10:35 PM
12/16/17 10:35 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Following this one
Re: Fast EZ-EFI amperage requirements? [Re: goldduster318] #2419661
12/16/17 11:51 PM
12/16/17 11:51 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The 160a Hemi alternator is a tad bit overkill for this car. Maybe I need a winch or something run. laugh2
2020 RAM 1500
Re: Fast EZ-EFI amperage requirements? [Re: MadMatt] #2419666
12/17/17 12:03 AM
12/17/17 12:03 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
I run a 70amp and I bet thats why my fuel pressure dips at idle
Re: Fast EZ-EFI amperage requirements? [Re: MadMatt] #2419697
12/17/17 01:23 AM
12/17/17 01:23 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
FWIW, the latest issue of Mopar Action has a good article on charging systems, including the bypass, voltmeter, etc. Also points out the need for heavier-gauge wiring to handle increased amperage.
Re: Fast EZ-EFI amperage requirements? [Re: topside] #2420478
12/18/17 06:13 PM
12/18/17 06:13 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
It's not in the Dec 2017 issue?
Re: Fast EZ-EFI amperage requirements? [Re: MadMatt] #2420510
12/18/17 06:51 PM
12/18/17 06:51 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I'm running a powermaster squareback. I've never had a mopar charge like this. The car was always burning up voltage regulators before. I always blamed the cheap vr. I'm not running a ton of stuff but I have upgraded headlights, ez efi, the in tank pump, stereo, and dash full of auto meter gauges. Before the blinkers would slow down, headlights would dim. All that stuff, now it's nice and stable. I wasn't sure if it was going to be money well spent with it being hard to find good vr, but it seems to be working good.
Re: Fast EZ-EFI amperage requirements? [Re: JAMESDART] #2420839
12/19/17 09:04 AM
12/19/17 09:04 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
James what amp alternator are you running?
Re: Fast EZ-EFI amperage requirements? [Re: UCUDANT] #2421073
12/19/17 06:41 PM
12/19/17 06:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The Feb 2018 is the current issue.
Re: Fast EZ-EFI amperage requirements? [Re: MadMatt] #2421109
12/19/17 08:43 PM
12/19/17 08:43 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Box says90 amp / 50amp at idle.
Re: Fast EZ-EFI amperage requirements? [Re: MadMatt] #2421710
12/21/17 01:53 AM
12/21/17 01:53 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Thanks John and James up
Re: Fast EZ-EFI amperage requirements? [Re: MadMatt] #2422297
12/22/17 02:01 PM
12/22/17 02:01 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I know it is not for everyone but I put a GM CS140 alternator on my car and bypassed the ammeter and that is one of the best mods I have ever done to my car.
68 Barracuda Formula S 340
Re: Fast EZ-EFI amperage requirements? [Re: MadMatt] #2422443
12/22/17 08:14 PM
12/22/17 08:14 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I put the cs144 on my jeep. I had another one and made an attempt to put it on the duster, it wasn't looking to good. That was when I decided to just go with the powermaster.
Re: Fast EZ-EFI amperage requirements? [Re: John_Kunkel] #2422746
12/23/17 07:15 PM
12/23/17 07:15 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
"Current" issue ...I get it LOL
Re: Fast EZ-EFI amperage requirements? [Re: MadMatt] #2422826
12/23/17 09:46 PM
12/23/17 09:46 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I have the ez EFI on my 72 road runner, I run a late 90's Chrysler alternator, i have no issues.
