Fast EZ-EFI amperage requirements?
#2418611
12/14/17 07:27 PM
12/14/17 07:27 PM
Posts: 730 Nampa, ID
MadMatt
Nampa, ID
I'm installing an EZ-EFI 2.0 on my 1970 Dodge Dart. Trying to figure out if I need to upgrade my alternator. Can anyone tell me the amperage draw of the EZ-EFI 2.0?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Fast EZ-EFI amperage requirements?
[Re: MadMatt]
#2418761
12/14/17 11:44 PM
12/14/17 11:44 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
What engine? A delco 12si which can be had cheaply at 94A is an easy swap on a small block at least. They charge well at idle.
The picture is from my friend's car. But mine also has a 12si and I have a Megasquirt 3 Pro, 340lph Aeromotive fuel pump, and contour fans and the 78a version is still keeping up well.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#2418902
12/15/17 10:21 AM
12/15/17 10:21 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
...Megasquirt 3 Pro, 340lph Aeromotive fuel pump, and contour fans and the 78a version is still keeping up well. For what it's worth. I have an inductive ammeter setup on my MS3 and with the same fuel pump, ECU and fans, I can only pull about 35a once the fans are running. With headlights and the blower on high I hit about 60a. Not a problem for my charging system, though.
[Re: GoodysGotaCuda]
#2419094
12/15/17 04:56 PM
12/15/17 04:56 PM
MadMatt
Nampa, ID
[/quote]
For what it's worth. I have an inductive ammeter setup on my MS3 and with the same fuel pump, ECU and fans, I can only pull about 35a once the fans are running. With headlights and the blower on high I hit about 60a. Not a problem for my charging system, though. [/quote]
Thanks! That's really helpful.
#2419171
12/15/17 08:54 PM
12/15/17 08:54 PM
goldduster318
Lake Orion, MI
...Megasquirt 3 Pro, 340lph Aeromotive fuel pump, and contour fans and the 78a version is still keeping up well. For what it's worth. I have an inductive ammeter setup on my MS3 and with the same fuel pump, ECU and fans, I can only pull about 35a once the fans are running. With headlights and the blower on high I hit about 60a. Not a problem for my charging system, though. Yeah, This is probably why it can keep up. There isn't an original style mopar alternator that charges anywhere near 40A at idle, I think the SI will do about 50A at idle with my curb speed and pulley ratio. The 94A is probably a better choice but this one has been on the car for almost 6 years already
[Re: goldduster318]
#2419661
12/16/17 11:51 PM
12/16/17 11:51 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
...Megasquirt 3 Pro, 340lph Aeromotive fuel pump, and contour fans and the 78a version is still keeping up well. For what it's worth. I have an inductive ammeter setup on my MS3 and with the same fuel pump, ECU and fans, I can only pull about 35a once the fans are running. With headlights and the blower on high I hit about 60a. Not a problem for my charging system, though. Yeah, This is probably why it can keep up. There isn't an original style mopar alternator that charges anywhere near 40A at idle, I think the SI will do about 50A at idle with my curb speed and pulley ratio. The 94A is probably a better choice but this one has been on the car for almost 6 years already The 160a Hemi alternator is a tad bit overkill for this car. Maybe I need a winch or something run.
[Re: topside]
#2420478
12/18/17 06:13 PM
12/18/17 06:13 PM
Posts: 8,131 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
FWIW, the latest issue of Mopar Action has a good article on charging systems, including the bypass, voltmeter, etc. Also points out the need for heavier-gauge wiring to handle increased amperage. It's not in the Dec 2017 issue?
[Re: UCUDANT]
#2421073
12/19/17 06:41 PM
12/19/17 06:41 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
FWIW, the latest issue of Mopar Action has a good article on charging systems, including the bypass, voltmeter, etc. Also points out the need for heavier-gauge wiring to handle increased amperage. It's not in the Dec 2017 issue? The Feb 2018 is the current issue.
[Re: MadMatt]
#2422297
12/22/17 02:01 PM
12/22/17 02:01 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I know it is not for everyone but I put a GM CS140 alternator on my car and bypassed the ammeter and that is one of the best mods I have ever done to my car.
68 Barracuda Formula S 340
[Re: John_Kunkel]
#2422746
12/23/17 07:15 PM
12/23/17 07:15 PM
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
FWIW, the latest issue of Mopar Action has a good article on charging systems, including the bypass, voltmeter, etc. Also points out the need for heavier-gauge wiring to handle increased amperage. It's not in the Dec 2017 issue? The Feb 2018 is the current issue. "Current" issue ...I get it LOL
