A Little Pissed #2419514
12/16/17 04:56 PM
12/16/17 04:56 PM
MR_P_BODY Offline OP
I ordered retainers the other day.. got them from
summit(it was a drop shipment).. ordered 7* 1.500
with a step.. I checked them out today and see that
they are 1.437 dia.. these are packaged as a 768-16
which says 1.500.. I think they have the wrong ones
in the package.. gonna send them back.. but you
know how shipping is during this time frame
wave
Re: A Little Pissed [Re: MR_P_BODY] #2419530
12/16/17 05:32 PM
12/16/17 05:32 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If those are Comp retainers, then that is the number for a 1.430 to 1.460 spring with a 1.030 inner diameter, the one's that I found are 782-16 for 11/32 valve and 780-16 for a 3/8 valve, they are 1.500 od,,1.115 id and .690 inner id steps,,yeah shipping sucks this time of year. wave
Re: A Little Pissed [Re: dartman366] #2419534
12/16/17 05:46 PM
12/16/17 05:46 PM
I am running 11/32 valves
wave
Re: A Little Pissed [Re: MR_P_BODY] #2419542
12/16/17 06:00 PM
12/16/17 06:00 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The retainer doesn't have to be the same diameter as the spring, as long as the steps fit the springs properly.
My catalog shows a 768 as 1.400 OD, typically used with 1.437-1.500 springs.
Re: A Little Pissed [Re: MR_P_BODY] #2419543
12/16/17 06:00 PM
12/16/17 06:00 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
wave
guess it be if the inner diameter or diameters will fit then it would be the 780-16 set. luck don't know why but my catalog says 782 as 11/32 and 780 as 3/8 but summit says the opposite shruggy but they do have both in stock.
Re: A Little Pissed [Re: fast68plymouth] #2419549
12/16/17 06:07 PM
12/16/17 06:07 PM
So I guess I can use it.. thanks... now waiting
on the springs
wave
Re: A Little Pissed [Re: MR_P_BODY] #2419583
12/16/17 07:43 PM
12/16/17 07:43 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
wave
You have snow tires for it?
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: A Little Pissed [Re: B3422W5] #2419585
12/16/17 07:47 PM
12/16/17 07:47 PM
Nope.. on the 1st we head for southern Texas
for 2 1/2 months.. dont need them
EDIT
I dont even drive it when its cold out.. I dont have
heater in it yet.. I just keep it in the heated shop
when we are gone
wave
Re: A Little Pissed [Re: MR_P_BODY] #2419713
12/17/17 02:06 AM
12/17/17 02:06 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Just got some springs I ordered from Summit in 2 days, Sparks NV to Sandpoint ID by UPS, so you may not be waiting long.
