A Little Pissed
#2419514
12/16/17 04:56 PM
12/16/17 04:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I ordered retainers the other day.. got them from summit(it was a drop shipment).. ordered 7* 1.500 with a step.. I checked them out today and see that they are 1.437 dia.. these are packaged as a 768-16 which says 1.500.. I think they have the wrong ones in the package.. gonna send them back.. but you know how shipping is during this time frame
Re: A Little Pissed
[Re: MR_P_BODY]
#2419530
12/16/17 05:32 PM
12/16/17 05:32 PM
dartman366
Mt. Vernon, Ohio
If those are Comp retainers, then that is the number for a 1.430 to 1.460 spring with a 1.030 inner diameter, the one's that I found are 782-16 for 11/32 valve and 780-16 for a 3/8 valve, they are 1.500 od,,1.115 id and .690 inner id steps,,yeah shipping sucks this time of year.
Re: A Little Pissed
[Re: MR_P_BODY]
#2419542
12/16/17 06:00 PM
12/16/17 06:00 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The retainer doesn't have to be the same diameter as the spring, as long as the steps fit the springs properly.
My catalog shows a 768 as 1.400 OD, typically used with 1.437-1.500 springs.
Re: A Little Pissed
[Re: MR_P_BODY]
#2419543
12/16/17 06:00 PM
12/16/17 06:00 PM
dartman366
Mt. Vernon, Ohio
If those are Comp retainers, then that is the number for a 1.430 to 1.460 spring with a 1.030 inner diameter, the one's that I found are 782-16 for 11/32 valve and 780-16 for a 3/8 valve, they are 1.500 od,,1.115 id and .690 inner id steps,,yeah shipping sucks this time of year. I am running 11/32 valves guess it be if the inner diameter or diameters will fit then it would be the 780-16 set. don't know why but my catalog says 782 as 11/32 and 780 as 3/8 but summit says the opposite but they do have both in stock.
Re: A Little Pissed
[Re: fast68plymouth]
#2419549
12/16/17 06:07 PM
12/16/17 06:07 PM
MR_P_BODY
My catalog shows a 768 as 1.400 OD, typically used with 1.437-1.500 springs. So I guess I can use it.. thanks... now waiting on the springs
Re: A Little Pissed
[Re: MR_P_BODY]
#2419583
12/16/17 07:43 PM
12/16/17 07:43 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I ordered retainers the other day.. got them from summit(it was a drop shipment).. ordered 7* 1.500 with a step.. I checked them out today and see that they are 1.437 dia.. these are packaged as a 768-16 which says 1.500.. I think they have the wrong ones in the package.. gonna send them back.. but you know how shipping is during this time frame You have snow tires for it?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: A Little Pissed
[Re: B3422W5]
#2419585
12/16/17 07:47 PM
12/16/17 07:47 PM
MR_P_BODY
Nope.. on the 1st we head for southern Texas for 2 1/2 months.. dont need them EDIT I dont even drive it when its cold out.. I dont have heater in it yet.. I just keep it in the heated shop when we are gone
