Anyone running aftermarket mufflers on a T/A or AAR? #2419496
12/16/17 03:51 PM
12/16/17 03:51 PM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
And how do you like the sound?
I think there are only a handful of same side inlet/outlet mufflers. A flowmaster 88 series maybe, dynomax super turbo, and magnaflow.
I want to put a T/A look alike system on my car once I replace the springs and get enough ground clearance for mufflers. I currently have pipes out the side with Supertrapps on the end. They get me a lot of looks and questions, but they're restrictive and louder than I would like.
These would be mated up to headers, and I plan to find or make tips that don't have the neck down at the exit. Winder if I should also try to squeeze in short glasspack between header and muffler or maybe a straight section with an auger type muffler insert. I want mild and throaty but not loud and popping.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Anyone running aftermarket mufflers on a T/A or AAR? [Re: Michael Ecks] #2419509
12/16/17 04:40 PM
12/16/17 04:40 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
A friend restored a T/A and it had Spintech mufflers. Way too loud for me. They sound a little funny from the side anyway. I would keep them quiet as possible if it were mine.
Re: Anyone running aftermarket mufflers on a T/A or AAR? [Re: Dave Hall] #2419590
12/16/17 08:11 PM
12/16/17 08:11 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Dr Gas has rectangular NASCAR style tips that might work for you.
https://www.youtube.com/watch?v=jucWtepx6PU
Re: Anyone running aftermarket mufflers on a T/A or AAR? [Re: Neil] #2419595
12/16/17 08:48 PM
12/16/17 08:48 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
I used TTI headers and X pipe, Accurate mufflers and stock tips with the baffle removed. It took some work to get the X pipe to match up to the mufflers. Its not much louder that stock and still somewhat looks the part
NS1AAR
Re: Anyone running aftermarket mufflers on a T/A or AAR? [Re: Michael Ecks] #2420827
12/19/17 05:18 AM
12/19/17 05:18 AM
Earth
Rob C Offline
Rob C  Offline
Earth
The Dyno max mufflers would be a good choice for the sound your looking for.
Popping in the exhaust is more likely a fuel issue. Normally extra fuel gets into the system on throttle closing and creates the popping sound on deceleration.
You might get a glass pack before the mufflers, not afterward since room is very limited. I like the Magna flow because there insides retain the pipe diameter. They don’t neck down.
Also, an “X” pipe mellows the growling exhaust sound. Stay with ether true duals or use an “H” pipe.
