Anyone running aftermarket mufflers on a T/A or AAR?
#2419496
12/16/17 03:51 PM
12/16/17 03:51 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
And how do you like the sound?
I think there are only a handful of same side inlet/outlet mufflers. A flowmaster 88 series maybe, dynomax super turbo, and magnaflow.
I want to put a T/A look alike system on my car once I replace the springs and get enough ground clearance for mufflers. I currently have pipes out the side with Supertrapps on the end. They get me a lot of looks and questions, but they're restrictive and louder than I would like.
These would be mated up to headers, and I plan to find or make tips that don't have the neck down at the exit. Winder if I should also try to squeeze in short glasspack between header and muffler or maybe a straight section with an auger type muffler insert. I want mild and throaty but not loud and popping.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Anyone running aftermarket mufflers on a T/A or AAR?
[Re: Neil]
#2419595
12/16/17 08:48 PM
12/16/17 08:48 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
I used TTI headers and X pipe, Accurate mufflers and stock tips with the baffle removed. It took some work to get the X pipe to match up to the mufflers. Its not much louder that stock and still somewhat looks the part
NS1AAR
