Pull LCA forward? #2418827
12/15/17 01:57 AM
12/15/17 01:57 AM
norcal
JLaSalle Offline OP
JLaSalle  Offline OP
norcal
How much are some of you guys pulling your lower control arm forward after installing poly or nylon bushings in the LCA?I only pulled mine forward about 1/32" with the adjustable strut rod, because I didn't want to put the bushing in a bind. But now I'm wondering if I should pull the t bars out ( to check for binding) and pull the lower arm forward more (it's pulled all the way to the K at the other end)for more caster before I get it aligned.Track only car.Just curious how much some have pulled forward without binding.1/8"?1/4"?
1967 Coronet R/T
9.83 134mph. 470 cid st.6 heads
10x pro et track champion
Re: Pull LCA forward? [Re: JLaSalle] #2418842
12/15/17 02:27 AM
12/15/17 02:27 AM
Boise
Moparteacher Offline
Boise
That control arm should swing perpendicular to the center line of the car. Pulling it forward with the strut rod to increase positive caster would be an incorrect method, bind or not.
Re: Pull LCA forward? [Re: JLaSalle] #2418854
12/15/17 02:55 AM
12/15/17 02:55 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Jeff! Did you call Marcus? How about Steve Caldwell? He's got Lisa's front pretty dialed???
Re: Pull LCA forward? [Re: JLaSalle] #2418923
12/15/17 11:43 AM
12/15/17 11:43 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I modified my strut rods 3/8" shorter to gain caster. Car has been campaigned 5 years at 145+. 1.240 on footbrake. Front suspension has no issue.
Doug
Re: Pull LCA forward? [Re: Moparteacher] #2418947
12/15/17 01:02 PM
12/15/17 01:02 PM
norcal
JLaSalle Offline OP
JLaSalle  Offline OP
norcal
Yeah that was my way of thinking,but when you add the poly LCA bushing, it moves the LCA back a fair amount,so I lose all the caster that I'm gaining from the tubular upper arms I'm putting on.I hear both sides and I'm wanting some real world experience where guys pull it forward and don't have a problem.
1967 Coronet R/T
Re: Pull LCA forward? [Re: Dave Hall] #2418957
12/15/17 01:19 PM
12/15/17 01:19 PM
norcal
JLaSalle Offline OP
JLaSalle  Offline OP
norcal
[quote=Dave Hall]Jeff! Did you call Marcus? How about Steve Caldwell? He's got Lisa's front pretty dialed???
Have not Dave. Lots of different opinions on this,I'm finding,and I'd like to hear 'em. I was excited about getting extra Caster with my new tubular uppers, but didn't know I would be running into this situation with the new lca bushings.
I still have a lot of work to do on this thing to be ready for that first Sears race. fury
1967 Coronet R/T
Re: Pull LCA forward? [Re: dvw] #2418958
12/15/17 01:22 PM
12/15/17 01:22 PM
norcal
JLaSalle Offline OP
JLaSalle  Offline OP
norcal
[quote=dvw]I modified my strut rods 3/8" shorter to gain caster. Car has been campaigned 5 years at 145+. 1.240 on footbrake. Front suspension has no issue.
Doug
3/8" wow...thank you. I assume that's with a poly LCA bushing?
1967 Coronet R/T
Re: Pull LCA forward? [Re: JLaSalle] #2418961
12/15/17 01:24 PM
12/15/17 01:24 PM
Minn
SportF Offline
SportF  Offline
Minn
At 3/8", got any idea how much caster you gained from that?
Re: Pull LCA forward? [Re: JLaSalle] #2418980
12/15/17 01:54 PM
12/15/17 01:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It has offset Moog offset uppers in the forward position only, poly strut rod and poly lower bushings. 2.5 positive measured caster angle. This was with 3 degrees of forward rake measured at the rocker sill. So with a level chassis 5.5 degrees.
Doug
Re: Pull LCA forward? [Re: JLaSalle] #2418984
12/15/17 01:59 PM
12/15/17 01:59 PM
Renton Washington
Triple Threat Offline
Renton Washington
Jeff,
I did exactly what you're asking about when I switched to tubular uppers and adjustable strut rods. I can't recall how far we went, but it's been that way untouched for the last 5 years.
-Dustin
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Pull LCA forward? [Re: JLaSalle] #2419002
12/15/17 02:30 PM
12/15/17 02:30 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i was going to just run factory strut rods but my k-member was bent a little and the moog improved bushings i think might've been a little thick and one side not seated well, alignment numbers were bad.
i decided when i pulled it back apart to fix the kmember, i was just going to put some adjustable rods in so i could get both front wheels in the exact same spot.
i used the rear of the torsion bar sockets in the crossmember as a line and measured to a point i dropped from the front lower ball joint to spindle bolt. this was at ride height.
to set the length on the strut rods initially, i had the torsion bars out, i held the LCA in the approximate ride height position, pulled the arms forward and then set the strut rod to that length plus another turn out to give the arm a little preload/push back since the strut rod will move on a slight arc.
Re: Pull LCA forward? [Re: JLaSalle] #2419050
12/15/17 03:32 PM
12/15/17 03:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The method I used was to cut the ends off off the stock rods. Turned them down a touch on the lathe. This allowed the ends to slip fit into 3/4 x.090 moly tubing. Welded it all back up 3/8" shorter than the originals.
Doug
