Pull LCA forward?
#2418827
12/15/17 01:57 AM
12/15/17 01:57 AM
Posts: 69 norcal
JLaSalle
norcal
How much are some of you guys pulling your lower control arm forward after installing poly or nylon bushings in the LCA?I only pulled mine forward about 1/32" with the adjustable strut rod, because I didn't want to put the bushing in a bind. But now I'm wondering if I should pull the t bars out ( to check for binding) and pull the lower arm forward more (it's pulled all the way to the K at the other end)for more caster before I get it aligned.Track only car.Just curious how much some have pulled forward without binding.1/8"?1/4"?
1967 Coronet R/T 9.83 134mph. 470 cid st.6 heads 10x pro et track champion
Re: Pull LCA forward?
[Re: Moparteacher]
#2418947
12/15/17 01:02 PM
12/15/17 01:02 PM
Posts: 69 norcal
JLaSalle
norcal
That control arm should swing perpendicular to the center line of the car. Pulling it forward with the strut rod to increase positive caster would be an incorrect method, bind or not. Yeah that was my way of thinking,but when you add the poly LCA bushing, it moves the LCA back a fair amount,so I lose all the caster that I'm gaining from the tubular upper arms I'm putting on.I hear both sides and I'm wanting some real world experience where guys pull it forward and don't have a problem.
[Re: Dave Hall]
#2418957
12/15/17 01:19 PM
12/15/17 01:19 PM
Posts: 69 norcal
JLaSalle
norcal
[quote=Dave Hall]Jeff! Did you call Marcus? How about Steve Caldwell? He's got Lisa's front pretty dialed??? Have not Dave. Lots of different opinions on this,I'm finding,and I'd like to hear 'em. I was excited about getting extra Caster with my new tubular uppers, but didn't know I would be running into this situation with the new lca bushings. I still have a lot of work to do on this thing to be ready for that first Sears race.
[Re: dvw]
#2418958
12/15/17 01:22 PM
12/15/17 01:22 PM
Posts: 69 norcal
JLaSalle
norcal
[quote=dvw]I modified my strut rods 3/8" shorter to gain caster. Car has been campaigned 5 years at 145+. 1.240 on footbrake. Front suspension has no issue. Doug 3/8" wow...thank you. I assume that's with a poly LCA bushing?
[Re: JLaSalle]
#2418961
12/15/17 01:24 PM
12/15/17 01:24 PM
Posts: 1,211 Minn
SportF
Minn
At 3/8", got any idea how much caster you gained from that?
[Re: JLaSalle]
#2418984
12/15/17 01:59 PM
12/15/17 01:59 PM
Triple Threat
Renton Washington
Jeff,
I did exactly what you're asking about when I switched to tubular uppers and adjustable strut rods. I can't recall how far we went, but it's been that way untouched for the last 5 years.
-Dustin
