EFI trigger wheel with stock water pump #2401174
11/09/17 11:00 PM
11/09/17 11:00 PM
AndyF Offline OP
AndyF  Offline OP
Starting to see people request EFI for stock looking engines. I worked with Doty to build a version of his short pulley that has a mounting ring on the backside for the trigger wheel. This way a person can use the thicker ATI damper, the short Doty pulley and then bolt on a trigger wheel for EFI.
Here are a couple of pictures. This setup fits with my billet timing chain cover and an aluminum water pump housing. I'll have parts on the shelf by the end of the year. This setup is designed to run a stock water pump but a person could also use it with an electric water pump if they wanted.
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2401178
11/09/17 11:08 PM
11/09/17 11:08 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
As always, nice work, Andy.
[image][/image]
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2401222
11/10/17 01:16 AM
11/10/17 01:16 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Very cool!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2403299
11/13/17 11:50 PM
11/13/17 11:50 PM
AndyF Offline OP
AndyF  Offline OP
Turns out the bolt pattern clocking on the pulleys is wrong so I'll need to get that fixed. Shouldn't be a big issue but now I won't have parts ready to ship for a few more weeks.
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2403398
11/14/17 03:57 AM
11/14/17 03:57 AM
Granbury TX
Prochargedmopar Offline
Granbury TX
How much $ and how many teeth on the trigger wheel?
Also, what type of pickup and how much is the complete package?
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2403458
11/14/17 12:37 PM
11/14/17 12:37 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Go to:
http://www.fastmanefi.com/cnp-products-for-mopars
for the breakdown. I can get you whatever you need.
Re: EFI trigger wheel with stock water pump [Re: Prochargedmopar] #2403502
11/14/17 02:09 PM
11/14/17 02:09 PM
AndyF Offline OP
AndyF  Offline OP
Trigger wheels are the same 36-1 as my other wheels. They are designed to work with the Holley sensor. I've heard that FAST will accept 36-1 in the next software release. I think most of the higher end EFI systems accept input from a 36-1 trigger wheel.
Cost depends on what all you buy. Some people want a complete turn key system, others mix and match parts depending on what they are trying to build.
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2405241
11/18/17 12:08 AM
11/18/17 12:08 AM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
Small block option?
Re: EFI trigger wheel with stock water pump [Re: j.mcconnell] #2405245
11/18/17 12:23 AM
11/18/17 12:23 AM
AndyF Offline OP
AndyF  Offline OP
Originally Posted By j.mcconnell
Small block option?
The trigger wheel and the pulley will fit on a SB. You'll have to build your own bracket to hold the Holley sensor.
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2418772
12/15/17 12:07 AM
12/15/17 12:07 AM
Hanover, Ontario, Canada
Moparmatty Offline
Moparmatty  Offline
Are these new parts available yet?
Matt Tebbutt
Ontario, Canada
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2418773
12/15/17 12:12 AM
12/15/17 12:12 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
You can buy them through Mopar Rich, FastMan EFI. I have one and they are every bit as nice as the pictures.
www.fastmanefi.com
68 Barracuda Formula S 340
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2418836
12/15/17 02:12 AM
12/15/17 02:12 AM
Colorado
Bob J Offline
Bob J  Offline
Colorado
I'm waiting for mine from Rich. Andy as always your work looks great.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: EFI trigger wheel with stock water pump [Re: Bob J] #2418844
12/15/17 02:31 AM
12/15/17 02:31 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Should ship tomorrow
Re: EFI trigger wheel with stock water pump [Re: Moparmatty] #2418857
12/15/17 03:06 AM
12/15/17 03:06 AM
AndyF Offline OP
AndyF  Offline OP
I've gotten parts into stock and then shipped them. At the moment I'm out of stock but should have more parts on hand in a week.
I'm making a few different trigger wheel combinations at the moment so you have to be clear on what you are looking for. Some folks have been using the larger trigger wheels that I designed for electric water pumps by grinding clearance in the pump housing.
There is also some confusion on the timing covers. I designed the original kit to fit a Jesel belt drive but then people wanted brackets that fit stock covers and Indy covers and so on. I designed a second set of brackets that fit my billet covers but people still want to use steel covers so then I added some spacers to the kit.
I'll get some more pictures and part numbers up on my website in the next few weeks and hopefully that will make things clearer.
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2426912
01/01/18 02:36 AM
01/01/18 02:36 AM
AndyF Offline OP
AndyF  Offline OP
Okay, I'm in the process of updating my price sheet and website for 2018. I have some of these new pulley/trigger wheels in stock now as well as the sensor bracket assembly. Cost is kind of expensive in low volumes but that is just the way it goes in this business. At least we now have a solution that bolts on and works with a stock water pump and a stock belt location.
The trigger wheel and pulley combination comes as one unit and is part number AR065. The sensor bracket is a different assembly and it is part number AR226K. The sensor bracket is designed to fit on an AR224 billet timing cover but I include spacers in the kit so it will fit on a stock stamped cover.
The trigger wheel and pulley combo is designed to fit on the face of an ATI 917122E damper. Other dampers might be made to work but it is designed for the ATI. The pulley is single groove and is in the stock location so it will run the water pump and the alternator. I do not have any plans at the moment to make two groove pulleys.
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2426962
01/01/18 07:34 AM
01/01/18 07:34 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Is it even possible to do a stock location 2 groove pulley?
I would think it would sell as well or better than the single groove.
Not everybody that would buy this setup is building a race car. Power steering and A/C are gotta haves for a lot of people that actually drive their cars further than cruise night.
Kevin
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2427382
01/01/18 08:40 PM
01/01/18 08:40 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Has anybody talked with March Performance? I'm running a Sanden with power steering with the stock water pump. I received my crank wheel from Rich a few weeks ago but haven't put the motor together as I just put the dash together. I have 4 1/2 months before the first autocross. I will go v belt or Serpentine as my AC kit came with a V belt.
Re: EFI trigger wheel with stock water pump [Re: AndyF] #2427450
01/01/18 10:52 PM
01/01/18 10:52 PM
Wild West
M_D Offline
M_D  Offline
Wild West
I get requests for a double groove pulley several times per year. I suppose I should break down and make some. The volumes for Mopar stuff is small and sometimes it's hard to justify the time and expense to design and manufacture it.
