Re: edelbrook hemi heads
[Re: DoubleD]
#2418415
12/14/17 12:23 PM
12/14/17 12:23 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I like those numbers ! Care to share some specs on the build ? Valve sizes, Cam specs , comp ratio, etc. Thanks, Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: cesar perez]
#2418421
12/14/17 12:31 PM
12/14/17 12:31 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
[Re: cesar perez]
#2418429
12/14/17 12:45 PM
12/14/17 12:45 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The Victor heads flow 420+ with fairly modest runner volumes and very little rework.
They're pretty nice.
[Re: fast68plymouth]
#2418527
12/14/17 04:26 PM
12/14/17 04:26 PM
Posts: 1,505 TN
SCATPACK 1
TN
They're pretty nice. Just curious about how the Eddys compare the the Indy HiPo heads that have the big valves. The look the same to me as if Edelbrock copied the Indy's.
Old Geezer Racing
[Re: cesar perez]
#2418541
12/14/17 04:47 PM
12/14/17 04:47 PM
fast68plymouth
So. Burlington, Vt.
The Victor head has a 245cc intake runner with a 2.32 intake valve..... The Indy hi-po is 266cc with a 2.40 valve.
[Re: DoubleD]
#2418597
12/14/17 06:46 PM
12/14/17 06:46 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
Sweet engine & nice power. Almost the exact same power & torque #'s my 528" Hemi Made.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: DoubleD]
#2418619
12/14/17 07:46 PM
12/14/17 07:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You put the motor plate mounts on the wrong side of the plate.. just makes it harder to get the engine out because you have to go up and over the mounts.. always put the mounting plate to the rear
[Re: MR_P_BODY]
#2418628
12/14/17 07:54 PM
12/14/17 07:54 PM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
You put the motor plate mounts on the wrong side of the plate.. just makes it harder to get the engine out because you have to go up and over the mounts.. always put the mounting plate to the rear That was just a test fit - had to move the HEMI back a 1/2 inch from where the wedge was- they are in the right place now - you guys don't miss a thing .........
[Re: cesar perez]
#2418644
12/14/17 08:16 PM
12/14/17 08:16 PM
Posts: 7,493 Minnesota
Hemi_Joel
Minnesota
DD, for your dyno test are those heads out of the box, or is there some work done on them? THose are some stout numbers.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
#2418668
12/14/17 09:00 PM
12/14/17 09:00 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
They're pretty nice. Do you mind saying what type of rework? Valve Job? Bowl blend? Something else?
