RACEPAK QUESTION #2418292
12/14/17 01:20 AM
12/14/17 01:20 AM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
Anybody here use a racepak on their car? I have a question about the magnetic collar on the Strange U1598 Yoke. Should I use a 2,4, or 8 magnet collar? Any up side to more magnetic triggers?
Real Men shift for themselves
Re: RACEPAK QUESTION [Re: 1DGEMAN] #2418340
12/14/17 03:50 AM
12/14/17 03:50 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Read the instructions. They talk about one or two with my Sportsman unit. Never heard of using 8??? "Seems the Water Boy is a cheetah".... haha
Re: RACEPAK QUESTION [Re: 1DGEMAN] #2418401
12/14/17 11:57 AM
12/14/17 11:57 AM
Columbus, OH
Ben Holt Offline
Ben Holt  Offline
Columbus, OH
The more magnets, the better the resolution, at least early in the run, you will have with the driveshaft RPM. It's more beneficial on a fast, stick shift car (Pro Stock or Pro Mod or the like) because we are really looking hard at those early numbers to diagnose shake, ET, etc. It can't hurt on a slower ET type car, but I don't think you will see much of a difference. If you have some type of traction control or timing control that uses DS, like a Davis or an MSD grid setup, then you have to have 8 magnets, and the control unit and the Racepak can then share the collar.
Whichever you decide to get you just have to make sure you go into the config file and select the amount of magnets so that the graph will display the correct amount.
On a regular bracket car it just comes down to how much you want to spend. The 2 magnet is cheaper than the 8. But, you can never have too much data.....
Re: RACEPAK QUESTION [Re: 1DGEMAN] #2418403
12/14/17 12:01 PM
12/14/17 12:01 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Go with the eight (8) magnet collar. More magnets more precision for measurement. If I remember the 8 magnet unit is not 8X in cost but only an amount less the 2X. You will like the Racepak once You are comfortable with operation and how to use all the information.
Re: RACEPAK QUESTION [Re: Dduster] #2418476
12/14/17 02:11 PM
12/14/17 02:11 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Gregg Kelly @ motorsports innovations told me since I already have a collar with 4 magnets it was plenty.
Gregg 609-265-2110
He's very helpful.
Don
Re: RACEPAK QUESTION [Re: cudadon] #2418483
12/14/17 02:29 PM
12/14/17 02:29 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Something else to look at is gear ratio and how quickly the yolk begins to turn in the first foot.. but I would think at least four...
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: RACEPAK QUESTION [Re: 1DGEMAN] #2418485
12/14/17 02:34 PM
12/14/17 02:34 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
Thanks for the replies. This is for a low 10 second stick shift small block
Stock Eliminator car.
Re: RACEPAK QUESTION [Re: 1DGEMAN] #2419784
12/17/17 12:10 PM
12/17/17 12:10 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
considered changing yokes when I installed mine, but I ended up simply installing the ring on the output shaft of the trans and drilled and tapped the tailshaft housing..... just throwing that out there.
