Restoring finish on carburetor #2417736
12/13/17 01:34 AM
12/13/17 01:34 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I have an old Carter AFB carburetor that I would like to rebuild and use. It is pretty grungy looking though so I would like to clean it up before I rebuild it. Is there something that I could dip/soak it in that will clean and brighten it up or am I going to have to bead blast it? Or is there some other method that works?
Re: Restoring finish on carburetor [Re: 440mopar] #2417750
12/13/17 01:55 AM
12/13/17 01:55 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Most cleaners today are mediocre at best,bead blasting will work but you must be sure to get "all" the beads out of "all" the passages.Other alternative is send it out and have it done right but it must be completely dissembled,that means every part removed from the casting.
Re: Restoring finish on carburetor [Re: 440mopar] #2417751
12/13/17 01:57 AM
12/13/17 01:57 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Send it to Scott;
http://www.harmsauto.com/
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Restoring finish on carburetor [Re: amxautox] #2418029
12/13/17 04:47 PM
12/13/17 04:47 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Tom...
What d'ya think???
Re: Restoring finish on carburetor [Re: amxautox] #2418048
12/13/17 05:18 PM
12/13/17 05:18 PM
New Mexico
JMCFAN Online content
JMCFAN  Online Content
New Mexico
Originally Posted By amxautox
Send it to Scott;
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Restoring finish on carburetor [Re: 440mopar] #2418084
12/13/17 06:25 PM
12/13/17 06:25 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Never glass bead aluminum.
Re: Restoring finish on carburetor [Re: 440mopar] #2418181
12/13/17 10:18 PM
12/13/17 10:18 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
If you glass bead the aluminum it opens the pours and makes it stain easier. SCOTT has a super secret method to restore carbs. They look very good.
Re: Restoring finish on carburetor [Re: fastmark] #2418203
12/13/17 11:02 PM
12/13/17 11:02 PM
New Mexico
New Mexico
My 70 Holley looks amazing!! Well worth the $$
Re: Restoring finish on carburetor [Re: JMCFAN] #2418284
12/14/17 01:11 AM
12/14/17 01:11 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Same thing goes for alternators.
Re: Restoring finish on carburetor [Re: fastmark] #2418315
12/14/17 02:01 AM
12/14/17 02:01 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The "finest" glass will not open the pores,just the opposite,after that ceramic tumbling is the final process.
Re: Restoring finish on carburetor [Re: 62maxwgn] #2418333
12/14/17 03:01 AM
12/14/17 03:01 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Very nice work that looks amazing.. up
Re: Restoring finish on carburetor [Re: 440mopar] #2418998
12/15/17 02:26 PM
12/15/17 02:26 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i am still experimenting on my stuff but getting there.
Re: Restoring finish on carburetor [Re: 440mopar] #2419229
12/15/17 10:54 PM
12/15/17 10:54 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
There are several threads on stripping and refinishing over on RFS.
Some pictures are missing due to the tapatalk takeover, but the content is still good. For example this one, even though it originally started about aluminim carb parts, the zinc ones are also discussed.
https://www.tapatalk.com/groups/racingfu...parts-t346.html
Re: Restoring finish on carburetor [Re: Mattax] #2419337
12/16/17 02:13 AM
12/16/17 02:13 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If done right,you can do very well with Zinc.
Re: Restoring finish on carburetor [Re: 440mopar] #2419458
12/16/17 02:02 PM
12/16/17 02:02 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Used to work in a buddy's carb restoration shop, and I can say that Scott does the absolute best work I've seen from anyone else. (my friend doesn't do holleys anymore or aftermarket or carbs for modified engines or I would drop his name)
My recommendation for an AFB at home where appearance isn't critical. 1) if its really gunky quick work with purple power and a nylon brush to get the crude off, no soaking because it reacts to aluminum, or skip to 2) Berryman Chem-Dip 3) Spray carb cleaner through all the passages followed by dry compressed air and let it dry COMPLETELY 4) bead blast with fine media 5) clean out all the passages with more compressed air and any picks, needles, bent wires needed to poke up into passages. If there is any water in the passages, the glass beads and dust are hard to remove completely 6) clear coat the castings outside surfaces only.
As to some of the other pics here, zinc in a can, eastwood carb renew, and what the holley shop does looks like crap in my opinion. I opened up a lot of original carbs at my friends shop and never saw that color. Original coated zinc castings have a unique finish I can only describe as iridescent-ish, goldish light green that is hard to reproduce. Scott at Harms and my friend are the only ones that look right to me, hell even I can't get it right anymore trying to duplicate my friend's method.
In one of these pics you can see the difference between the tacky carb renew on the outside of the bowl and the original finish in the fuel inlet. The other is my street avenger I tried to make look more like a vintage carb by beadblasting and using an alodine solution and satin clear coat.
Interesting note. My friend's shop was contacted first to become the Holley's Custom Shop back when he did Holleys, being a one man and occasional helper business he turned them down because he didn't want to expand his business. So Holley went to someone else who does that horrible brown-gold refinish. It was after that started showing up at shows as "restoration" that "horrible brown gold in a can" came about.
100_0638.jpg22814013_2095358150478094_8827674937499104504_n.jpg22815159_2095358147144761_6351065397512846227_n.jpg
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Restoring finish on carburetor [Re: 440mopar] #2419460
12/16/17 02:06 PM
12/16/17 02:06 PM
Columbus, GA
Columbus, GA
By the way DO NOT USE those clear plastic sight plugs in my last picture! The new stuff they make them from WILL soften and break off in the bowl from nothing more than engine vibration.
Re: Restoring finish on carburetor [Re: Michael Ecks] #2422086
12/21/17 11:18 PM
12/21/17 11:18 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Scott does excellent work.
I soak mine in a few gallons of gas in a 5 gallon pail.
Turns all the gunk into a dusty residue that cleans off easily with small brass brushes.
Then the small bits and linkages get cleaned in a rock tumbling outfit.
I have mechanical Aptitude.
I can screw up anything.
