Re: Restoring finish on carburetor
[Re: amxautox]
#2418029
12/13/17 04:47 PM
12/13/17 04:47 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: fastmark]
#2418203
12/13/17 11:02 PM
12/13/17 11:02 PM
Posts: 2,087 New Mexico
JMCFAN
New Mexico
If you glass bead the aluminum it opens the pours and makes it stain easier. SCOTT has a super secret method to restore carbs. They look very good. My 70 Holley looks amazing!! Well worth the $$
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: fastmark]
#2418315
12/14/17 02:01 AM
12/14/17 02:01 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
If you glass bead the aluminum it opens the pours and makes it stain easier. SCOTT has a super secret method to restore carbs. They look very good. The "finest" glass will not open the pores,just the opposite,after that ceramic tumbling is the final process.
[Re: 440mopar]
#2419229
12/15/17 10:54 PM
12/15/17 10:54 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
There are several threads on stripping and refinishing over on RFS. Some pictures are missing due to the tapatalk takeover, but the content is still good. For example this one, even though it originally started about aluminim carb parts, the zinc ones are also discussed. https://www.tapatalk.com/groups/racingfu...parts-t346.html
[Re: 440mopar]
#2419458
12/16/17 02:02 PM
12/16/17 02:02 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Used to work in a buddy's carb restoration shop, and I can say that Scott does the absolute best work I've seen from anyone else. (my friend doesn't do holleys anymore or aftermarket or carbs for modified engines or I would drop his name)
My recommendation for an AFB at home where appearance isn't critical. 1) if its really gunky quick work with purple power and a nylon brush to get the crude off, no soaking because it reacts to aluminum, or skip to 2) Berryman Chem-Dip 3) Spray carb cleaner through all the passages followed by dry compressed air and let it dry COMPLETELY 4) bead blast with fine media 5) clean out all the passages with more compressed air and any picks, needles, bent wires needed to poke up into passages. If there is any water in the passages, the glass beads and dust are hard to remove completely 6) clear coat the castings outside surfaces only.
As to some of the other pics here, zinc in a can, eastwood carb renew, and what the holley shop does looks like crap in my opinion. I opened up a lot of original carbs at my friends shop and never saw that color. Original coated zinc castings have a unique finish I can only describe as iridescent-ish, goldish light green that is hard to reproduce. Scott at Harms and my friend are the only ones that look right to me, hell even I can't get it right anymore trying to duplicate my friend's method.
In one of these pics you can see the difference between the tacky carb renew on the outside of the bowl and the original finish in the fuel inlet. The other is my street avenger I tried to make look more like a vintage carb by beadblasting and using an alodine solution and satin clear coat.
Interesting note. My friend's shop was contacted first to become the Holley's Custom Shop back when he did Holleys, being a one man and occasional helper business he turned them down because he didn't want to expand his business. So Holley went to someone else who does that horrible brown-gold refinish. It was after that started showing up at shows as "restoration" that "horrible brown gold in a can" came about.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: 440mopar]
#2419460
12/16/17 02:06 PM
12/16/17 02:06 PM
Michael Ecks
Columbus, GA
By the way DO NOT USE those clear plastic sight plugs in my last picture! The new stuff they make them from WILL soften and break off in the bowl from nothing more than engine vibration.
[Re: Michael Ecks]
#2422086
12/21/17 11:18 PM
12/21/17 11:18 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Scott does excellent work.
I soak mine in a few gallons of gas in a 5 gallon pail. Turns all the gunk into a dusty residue that cleans off easily with small brass brushes. Then the small bits and linkages get cleaned in a rock tumbling outfit.
I have mechanical Aptitude. I can screw up anything.
