'67 b-body hood interchange #2416725
12/11/17 01:05 PM
12/11/17 01:05 PM
Pasadena, Texas
fal3 Offline OP
fal3  Offline OP
Pasadena, Texas
I've a '67 GTX. Need clarification for hood exchanges. Did a search on Moparts, and the info claims a 66-67 Coronet, Charger, Belvedere, or Satellite hoods will interchange. Some members replied that a 68-70 hood will interchange, but there was a difference of opinion as to whether that would actually work w/o major surgery to make the hood fit. I just want to take off my original hood and swap in another hood. The purpose is I want to install a hood scoop and do not want to cut up my original hood. A google search just took me to either vendors selling hoods or posts that had little to no info of help; FBO was of no use when I visited their site.
Re: '67 b-body hood interchange [Re: fal3] #2416728
12/11/17 01:09 PM
12/11/17 01:09 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I thought the 67 plymouth belvedere, satellite and gtx hoods were by the selves, with possibly 66 too.
Re: '67 b-body hood interchange [Re: fal3] #2416742
12/11/17 01:38 PM
12/11/17 01:38 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Dodge and Plymouth are way different so coronet and charger won't work.
Re: '67 b-body hood interchange [Re: fal3] #2417890
12/13/17 01:00 PM
12/13/17 01:00 PM
Pasadena, Texas
fal3 Offline OP
fal3  Offline OP
Pasadena, Texas
Ok, nobody seems to know about interchange. Let's take another route. Can someone recommend a vendor that makes a quality metal hood for a '67 b-body? Seems to be a lot of choices for most popular Mopars, but limited choices for the year '67.
Re: '67 b-body hood interchange [Re: fal3] #2417947
12/13/17 02:28 PM
12/13/17 02:28 PM
crlush Offline
crlush  Offline
Nobody that I know of. Like said before the plymouth and dodge hoods are totaly different in the front.
Re: '67 b-body hood interchange [Re: fal3] #2417981
12/13/17 03:32 PM
12/13/17 03:32 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
66 Coronet hoods are different than 67, but will work. Can't imagine it wouldn't "fit", may just not look right because of design nuances.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: '67 b-body hood interchange [Re: A39Coronet] #2417992
12/13/17 04:07 PM
12/13/17 04:07 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I used a 66 coronet hood on my 67 coronet and it fit perfect. Not sure about the 66-67 charger hoods but they look like they would work.
Re: '67 b-body hood interchange [Re: rapom] #2418087
12/13/17 06:35 PM
12/13/17 06:35 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
'67 Coronet and Belvedere hoods are different. Check how the front lip is formed, Coronet turns straight down, Beledvere turns down, then back, which makes for a place to hold moisture for rust. Clean Coronet hoods are easier to find.
To answer your question, you will need a '66 or '67 Belvedere hood. Check for rust on the front lip pinch welds, if rust free, rest of hood should be good.
IIRC, there is another difference between '66 and '67 Belvedere hoods (if not the hood, then the trunk lid). One of the holes for the 'Plymouth' emblems are in a different location.
Re: '67 b-body hood interchange [Re: fal3] #2418250
12/14/17 12:18 AM
12/14/17 12:18 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
The ONLY hoods that will interchange for your car are 1966 and 1967 Plymouth b-body. Period! You need to find one of these to put a scoop on.
Re: '67 b-body hood interchange [Re: fal3] #2418889
12/15/17 06:50 AM
12/15/17 06:50 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Have you considered a fiberglass hood?
Talk to Larry "The Glass Man" here on Moparts.
The Glass Man
His contact info from a post a few years ago on here, Not sure if it's current.
sledcity@aol.com or call 1-614-875-0369
