97 Ram 2500cooling fan removal question #2412333
12/02/17 06:57 PM
12/02/17 06:57 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
Does anyone have the size of the nut that holds the clutch fan on to the water pump? any tricks for getting it off?
Re: 97 Ram 2500cooling fan removal question [Re: 3wracing] #2412358
12/02/17 08:01 PM
12/02/17 08:01 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
It threads off in a counterclockwise direction.
Get the longest chisel or heavy standard screwdriver you can find and while the belt is still on, set up the chisel on the left edge of the nut and use a heavy hammer to give it a sharp smack. It sould break loose pretty easy and spin right of by hand the rest of the way.
Re: 97 Ram 2500cooling fan removal question [Re: stumpy] #2412541
12/03/17 02:18 AM
12/03/17 02:18 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
1 7/16
my ladder of success is missing some rungs
Re: 97 Ram 2500cooling fan removal question [Re: 3wracing] #2412617
12/03/17 11:36 AM
12/03/17 11:36 AM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
Thankyou
Re: 97 Ram 2500cooling fan removal question [Re: 3wracing] #2412659
12/03/17 01:48 PM
12/03/17 01:48 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the diesel threads are opposite----since you didnt mention what the motor was......
Re: 97 Ram 2500cooling fan removal question [Re: savoy64] #2412748
12/03/17 06:37 PM
12/03/17 06:37 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
gas . so its right hand threads correct?
Re: 97 Ram 2500cooling fan removal question [Re: 3wracing] #2413044
12/04/17 01:37 PM
12/04/17 01:37 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
gas---right------- diesel left....stumpy is right on the chisel hit---i use an air chisel----most wrenches too fat to put on the nut---there is a special tool.....
Re: 97 Ram 2500cooling fan removal question [Re: 3wracing] #2413355
12/05/17 12:47 AM
12/05/17 12:47 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I just use a big set of channel locks. Grab the nut tight, smack the end of the handles. The ones I've loosened were not that tight. Gene
Re: 97 Ram 2500cooling fan removal question [Re: savoy64] #2413387
12/05/17 01:50 AM
12/05/17 01:50 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Yep found that out the hard way!
Re: 97 Ram 2500cooling fan removal question [Re: 3wracing] #2413497
12/05/17 11:29 AM
12/05/17 11:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
FYI not all the Cummins are LHT. Believe they changed that with the common rail in 03 (IIRC)... beware smile
I have a long piece for my air chisel that knocks them right off.
Re: 97 Ram 2500cooling fan removal question [Re: 3wracing] #2417888
12/13/17 12:58 PM
12/13/17 12:58 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
It is officially a 36 mm.
I have shimmed english wrenches with a flattened out piece of lead plumbing solder to get a tight fit, and also with aluminum can metal.
As said above a quick whack with a 2 lb hammer usually is all it takes to loosen it.
Re: 97 Ram 2500cooling fan removal question [Re: stumpy] #2419303
12/16/17 12:41 AM
12/16/17 12:41 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Having the right tool is nice but as Stumpy said this works as I did it a few times myself. I had an old big screwdriver blade that was about 2 to 3 ft long and the handle broke off years earlier so I used it like a chisel and it worked great for this. Like was said make sure you get it near the edge so it hits its force in the right direction and usually one good hit with a nice size hammer did it for me. Ron
Re: 97 Ram 2500cooling fan removal question [Re: 383man] #2420065
12/17/17 11:00 PM
12/17/17 11:00 PM
IN
ahy Offline
ahy  Offline
IN
The "put a wrench on it and whack it with a hammer" (in the correct direction!) has usually worked for me. Except with a Durango. For some reason locktite was applied to to the threads. After all else failed I fabricated a holding tool with pins. That did it. No locktight on re-install. Kinda like the factory tool?
