Affordable street strip electric fuel pump #2417193
12/12/17 04:37 AM
12/12/17 04:37 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
The mallory 140 on my car seems to have died. Looked up the price for a new 140 and immediately was hit with sticker shock. At least 2 times higher than what I paid for the pump however many years ago. 325 seems pretty dang high for a 140..
What is an affordable (like to stay around $200), quality, reliable pump in the 140 gph range these days?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Affordable street strip electric fuel pump [Re: Von] #2417208
12/12/17 06:23 AM
12/12/17 06:23 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I use the SX Fuelsystems pump. No longer in business but i believe it to be same as the Edelbrock 160 quite flow. $210. Iv had this pump in operation for 12 yrs now. No issues yet.
Re: Affordable street strip electric fuel pump [Re: Von] #2417233
12/12/17 09:57 AM
12/12/17 09:57 AM
pa
572charger Offline
572charger  Offline
pa
aeromotive 11203 had 2 on my car for over 15 yrs no problems !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Affordable street strip electric fuel pump [Re: Von] #2417368
12/12/17 03:03 PM
12/12/17 03:03 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Considering a walbro external pump.
Anybody used one?
Re: Affordable street strip electric fuel pump [Re: Von] #2417372
12/12/17 03:13 PM
12/12/17 03:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You might want to think 2 pumps in parallel
instead of 1 bigger pump.. your looking for
flow not pressure.. I have been running 2
pumps on the race car since day 1.. they dont
need to be pricey.. the one thing about cheaper
pumps is they tent to be a little noisier.. but
if you isolate them they arent bad
EDIT
Also if one dies you can still make it home
or back to the pits
wave
Re: Affordable street strip electric fuel pump [Re: Von] #2417462
12/12/17 05:38 PM
12/12/17 05:38 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Anybody used one?
If you going mechanical. Then go with a Clay Smith.
Re: Affordable street strip electric fuel pump [Re: rt66jim] #2417489
12/12/17 06:30 PM
12/12/17 06:30 PM
dogdays Offline
dogdays  Offline
I'd pick a couple of Walbro 255 lph pumps mounted in the fuel tank if I was starting from scratch.pump them in parallel.
I am seeing Carter external mount rotary vane electric pumps or clones on Ebay for not too much money. I have had exceptional luck with that kind for street use. Again to get the flow you want you need two in parallel.
R.
Re: Affordable street strip electric fuel pump [Re: Von] #2417535
12/12/17 07:32 PM
12/12/17 07:32 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I prefer the Carter. It's a Mopar thing. Cheap, simple, small and it works.
2011 Drag Pak Challenger
Re: Affordable street strip electric fuel pump [Re: Von] #2417548
12/12/17 08:10 PM
12/12/17 08:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Von I know some say they are too noisey but I have always run Holley pumps since the 70's. The one I run now is the black one with a reg set at 6 psi and it supplies my 850 fine with 3/8 line. Myself when you grew up wanting to hear that fuel pump when you turn the key on as that way I knew it was working so a little fuel pump noise does not bother me at all in my hotrod running 3" exh with Ultra-Flow mufflers. And I have never been let down on the road by a Holley pump but I did have one go bad from sitting a few years as it locked up. But thats all I use is just the Holley electric pump and its cost was not that bad. Ron
Re: Affordable street strip electric fuel pump [Re: rt66jim] #2417721
12/13/17 01:14 AM
12/13/17 01:14 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Anybody used one?
Walbro pump is electric.
Re: Affordable street strip electric fuel pump [Re: Von] #2417726
12/13/17 01:19 AM
12/13/17 01:19 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Ron,
I used blues and reds "back in the day"...
Had one or two die. But...they were dead headed. I have a return now, so I assume their life should be longer, and probably quieter.
Re: Affordable street strip electric fuel pump [Re: Von] #2417738
12/13/17 01:39 AM
12/13/17 01:39 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I put lots of miles and lots of years on a holley blue. I never had it let me down, I started to carry a spare when I did drag week but never needed it.
With my EFI I run two walboro 255LPH pumps. I killed one pump on drag week and had a second one die almost instantly. Looking back on it the problem was teething pains from a new EFI fuel system and not cleaning the 10 micron filter often enough. Since then I have had no problems with the walboro pumps mounted externally.
68 Barracuda Formula S 340
Re: Affordable street strip electric fuel pump [Re: Von] #2417778
12/13/17 03:23 AM
12/13/17 03:23 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run a Carter system on the Satellite.... mechanical 6903 pump full time on the street. It also has a 4600HP electric pump in series back near the tank. I run a one-way check valve around it so the mechanical can pull around it, but when I turn it on it pushes to the mechanical. I use the electric pump to prime when the cars been sitting and at the track only. This setup seems to work real well so far.
Re: Affordable street strip electric fuel pump [Re: Von] #2417782
12/13/17 03:30 AM
12/13/17 03:30 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Anybody used the Big End electric pumps? I see reference as to them actually being made by Holley??
Re: Affordable street strip electric fuel pump [Re: Von] #2417783
12/13/17 03:31 AM
12/13/17 03:31 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Clark,
Was ur blue setup dead or return?
Re: Affordable street strip electric fuel pump [Re: Von] #2417840
12/13/17 11:38 AM
12/13/17 11:38 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Yeah, the Mallory pump price has gotten ridiculous. The only reason I bought a new 140 to replace my old 140 was because I scored a $50 off $250+ purchase Summit coupon. Otherwise, I'd have looked elsewhere, too. I was leaning towards an Aeromotive before I got the Summit deal.
Re: Affordable street strip electric fuel pump [Re: 572charger] #2417842
12/13/17 11:48 AM
12/13/17 11:48 AM
an8sec70cuda Offline
iagree I ran one of those Aeromotive 11203 pumps on the cuda for a long time and really liked it. It's on my road runner now. A little over $200, so right where you want to be price wise.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Affordable street strip electric fuel pump [Re: Von] #2417859
12/13/17 12:19 PM
12/13/17 12:19 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Can a mechanical pump pull through a bad electric pump? I thought that we did this back in the 70's but don't remember if we plumbed it differently.
Re: Affordable street strip electric fuel pump [Re: Von] #2417902
12/13/17 01:28 PM
12/13/17 01:28 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Von the blue pump was dead headed. There was times it made some pretty bad noises on drag week when it was hot but it never failed. It was supporting about 450-500HP pulling through the stock 5/16 pickup.
Re: Affordable street strip electric fuel pump [Re: Von] #2417928
12/13/17 02:04 PM
12/13/17 02:04 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I hate noisy elec pumps (holley blue), so when a short pushrod took out the cam lobe on my Hemi, I got a Holley HP 150ghp gearrotor pump & it was SUPER quiet. Could barely hear it with the motor idling. They're $237 at Summit. Also run the Mallory gearrotor design 110 gph pump on my sweptlines 383's and they're even quieter. Their 140 gph pump is $287 vs the Holley 150 at $237 so I'd get the Holley.
