Fiberglass or steel repro hood, which should I use. #241778
03/03/09 10:05 AM
03/03/09 10:05 AM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
I am thinking about putting a fiberglass shaker hood on my car. AAR fiberglass Reproductions make a non functional shaker hood with the bubble attached. That would work well on my car as I am putting in a new 6.4 hemi in the car and it is fuel injected. Has anyone used products from this company? I was curious about the quality and if the hood would look just like steel after painting.
While I am on the subject how are the new steel shaker hoods. I see that AMD has one and I think Goodmark also. Could one of those be made as a non functional shake. Would the steel be better than the fiberglass.
Re: Fiberglass or steel repro hood, which should I use. [Re: batt2rm] #241779
03/03/09 10:57 AM
03/03/09 10:57 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
AAR has a pretty good rep from what I have read here. However I'd prefer a steel hood, the repop stuff is pretty nice.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Fiberglass or steel repro hood, which should I use. [Re: batt2rm] #241780
03/03/09 02:01 PM
03/03/09 02:01 PM
Jacksonville Florida
elitecustombody Offline
I'd go with metal,fiberglass hoods are never perfect,also keep in mind most of the time you have to change the springs or hinges if you go with fiberglass,or you will have cracks from trying to shut it,as most glass hoods are lighter than metal
Re: Fiberglass or steel repro hood, which should I use. [Re: elitecustombody] #241781
03/03/09 02:06 PM
03/03/09 02:06 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I've seen functional shakers used on new HEMI's. I'm sure there's a way to get everything to work. I would have a problem with having a non functional shaker. I think it would end up looking like the hood on that Hot Rod Stratus R/T from a few years back.
Re: Fiberglass or steel repro hood, which should I use. [Re: burdar] #241782
03/03/09 03:35 PM
03/03/09 03:35 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
The ones from AAR in FL are real nice from what I have seen.
They are a hevy glass hood and are a great value if on a budjet and the car is just a hot rod. They do make springs for them.
Realy depends on how much you want to spend. Looking at 4 times as much for a repro steel one and all the other stuff to go with it. Shaker parts are not cheap at all.
Add up the price of a steel AMD one with ring, and all the stuff it needs at shakerhood.com
Ben Snowbar sells everything else.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
