318 upgrades for cheap????
#241761
03/03/09 09:43 AM
03/03/09 09:43 AM
Posts: 173 Indiana
swepty
Indiana
Recently bought my wife a grand chherokee with a 318, and was wondering what upgrades you guys recommend that are easy on my ever shrinking wallet. I just put a 40 series flowmaster on, and it has just had a general tune up, plugs wires cap rotor, etc... Any ideas, or suggestions would be appreciated!!
1976 CREW CAB 3/4 ton 4x4 Factory plow and ex Airforce Truck
1986 Power Ram 400hp 360 6" lift
1970 Plymouth custom suburban 318 4" drop
1996 Dodge 1500 360 4wd 3" lift
North Central Indiana Mopar Club member
Re: 318 upgrades for cheap????
[Re: swepty]
#241762
03/03/09 10:30 AM
03/03/09 10:30 AM
RapidRobert
A good plan is to attack the worst(most restricted) area 1st which would be the exhaust(add headers & a mandrel 2&1/2" system)(always thinking of the engine in terms of an airpump). If it has a carter 2bbl You can even use the pri jets in an eddy strip kit to rejet it. Better yet obtain an edel performer alum intake which does have a spreadbore carb pattern(they're cheap) with a demonsizler prepped thermoquad. EDIT I forgot about recurving the dist/timing also
[Re: burdar]
#241764
03/03/09 11:04 AM
03/03/09 11:04 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I'd do a high flow cat, can be bought for 50-75 and on my truck I picked up 2mpg. A could air intake would help some too and like mentioned can be found cheap. Otherwise your going to pay a good bit to get anything else done.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: swepty]
#241767
03/03/09 12:57 PM
03/03/09 12:57 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I put underdrive pulleys on my Lincoln 5.0 and it made a noticeable difference.
Homemade cold-air pipe helped me also. On a mass airflow system the meter might be a bigger restrictor than the airbox, so look it over before spending $$$.
There might be some Bosch Type 2-3 (?) injectors that give better atomization and therefore more MPG and power. Search Ebay for cleaned injectors and you'll eventually stumble on the info. 'Cleaned' injectors are pretty reasonably priced ($80-100 for 8 of them).
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: dart4forte]
#241771
03/04/09 07:05 PM
03/04/09 07:05 PM
Posts: 173 Indiana
swepty
Indiana
I have already switched and put synthetic in all.
I just want to do what i can that is fairly subtle, so that when I drive it, it's what I want. Don't want to be out done by those import suv junks while at a stop light!!!
[Re: Mr.Yuck]
#241772
03/04/09 07:07 PM
03/04/09 07:07 PM
Posts: 173 Indiana
swepty
Indiana
It is a 96. I would definately be interested in a mp computer, if any one knows of one that will work let me know.
