318 upgrades for cheap???? #241761
03/03/09 09:43 AM
03/03/09 09:43 AM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
Recently bought my wife a grand chherokee with a 318, and was wondering what upgrades you guys recommend that are easy on my ever shrinking wallet. I just put a 40 series flowmaster on, and it has just had a general tune up, plugs wires cap rotor, etc...
Any ideas, or suggestions would be appreciated!!
1976 CREW CAB 3/4 ton 4x4 Factory plow and ex Airforce Truck 1986 Power Ram 400hp 360 6" lift 1970 Plymouth custom suburban 318 4" drop 1996 Dodge 1500 360 4wd 3" lift North Central Indiana Mopar Club member
Re: 318 upgrades for cheap???? [Re: swepty] #241762
03/03/09 10:30 AM
03/03/09 10:30 AM
A good plan is to attack the worst(most restricted) area 1st which would be the exhaust(add headers & a mandrel 2&1/2" system)(always thinking of the engine in terms of an airpump). If it has a carter 2bbl You can even use the pri jets in an eddy strip kit to rejet it. Better yet obtain an edel performer alum intake which does have a spreadbore carb pattern(they're cheap) with a demonsizler prepped thermoquad. EDIT I forgot about recurving the dist/timing also
Re: 318 upgrades for cheap???? [Re: RapidRobert] #241763
03/03/09 10:59 AM
03/03/09 10:59 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If your talking about a Jeep...you have a 5.2L Magnum and not the LA 318 right.
The muffler is a good start but I would have gone with the 50 series muffler. I think the 40 is going to be too loud for you but that is personal preference. THe rest of the exhaust system should be pretty good as the factory system was already mandrel bent. Headers might add some power but they are NOT going to be cheap.
You are probably not going to put a carb on a fuel ingected engine so that is out. I would put on an after market intake system. Some of them can be spendy but I found a cheap one on E-bay for my 00 Durango. It looks and sounds great.
THey do have some magnum intakes on the market as well as the magnum R/T heads but that is getting into a lot of money. I'm pretty happy with my Durango and all I have done to the 4.7L is a 50 series Flowmaster and a different air intake kit.
Re: 318 upgrades for cheap???? [Re: burdar] #241764
03/03/09 11:04 AM
03/03/09 11:04 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I'd do a high flow cat, can be bought for 50-75 and on my truck I picked up 2mpg. A could air intake would help some too and like mentioned can be found cheap. Otherwise your going to pay a good bit to get anything else done.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 318 upgrades for cheap???? [Re: burdar] #241765
03/03/09 11:04 AM
03/03/09 11:04 AM
Oh I was thinking LA
Re: 318 upgrades for cheap???? [Re: Silver70] #241766
03/03/09 12:23 PM
03/03/09 12:23 PM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
What do you guys think about a jet chip or someting like that? Underdrive pulley?
Re: 318 upgrades for cheap???? [Re: swepty] #241767
03/03/09 12:57 PM
03/03/09 12:57 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I put underdrive pulleys on my Lincoln 5.0 and it made a noticeable difference.
Homemade cold-air pipe helped me also. On a mass airflow system the meter might be a bigger restrictor than the airbox, so look it over before spending $$$.
There might be some Bosch Type 2-3 (?) injectors that give better atomization and therefore more MPG and power. Search Ebay for cleaned injectors and you'll eventually stumble on the info. 'Cleaned' injectors are pretty reasonably priced ($80-100 for 8 of them).
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: 318 upgrades for cheap???? [Re: Fury Fan] #241768
03/03/09 01:42 PM
03/03/09 01:42 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I have a hard time believing that chips make a big difference in a gas engine. Pulleys can give you more power, but I've heard bad things about them too. I've heard that under stop and go trafic the alt might not be putting out enough voltage. I've heard of the check engine light coming on in certain models exc...
One other thing you may consider is replacing the engine driven cooling fan with an electric. I know that the Dakota R/T guys do this and seem to like it. One thing to remember is that the electric fan may not be enough to keep the Jeep cool on hot days with the air on.
Re: 318 upgrades for cheap???? [Re: swepty] #241769
03/03/09 02:14 PM
03/03/09 02:14 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
if she's like my wife she has a heavy foot. A little emphasis in that area may help. Seriously, you may want to consider synthetic oil in the engine, tranny and rear end.
Re: 318 upgrades for cheap???? [Re: dart4forte] #241770
03/03/09 02:33 PM
03/03/09 02:33 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what year? if they make a MP computer get one. 20-30 HP in that alone. Hi-flow cat and 3" exhaust as well as getting some cool air into the engine. Headers are good but can be a pain and get expensive for 4x4's
Re: 318 upgrades for cheap???? [Re: dart4forte] #241771
03/04/09 07:05 PM
03/04/09 07:05 PM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
I have already switched and put synthetic in all.
I just want to do what i can that is fairly subtle, so that when I drive it, it's what I want. Don't want to be out done by those import suv junks while at a stop light!!!
Re: 318 upgrades for cheap???? [Re: Mr.Yuck] #241772
03/04/09 07:07 PM
03/04/09 07:07 PM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
It is a 96. I would definately be interested in a mp computer, if any one knows of one that will work let me know.
