Page 4 of 9 1 2 3 4 5 6 7 8 9
Re: Most Powerfull 59 Degree Small Block Ever? [Re: Leigh] #24167
05/11/06 06:37 AM
05/11/06 06:37 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Mega a dart take a CHILL PILL if you dont like what other people have to say hang out at a chevy board
hey scottb, did you dethrone B3 as the new president of the Moparts A$$ kissing club?
Don't like what I said?, go hang somewhere else. FYI, I still own Mopar so will do as I please but will tell you this, most chevy guys I've met recently are way nicer then folks here. You can KMA
What does a .99 60' time in a BB Chevy powered RED
Sorry Ryan you've got the facts mixed up.
No BBC #'s there.
That is what the W5 pulled in a 23 tbucket 3 times before it melted the head...
I think those calculators are close for cars that are well sorted out. when my motor let go I was just starting to tune the chassis and feel it would've gone 1.22 60', 8.90 @ 152 but that is JMO. If I had a 3 speed probably would've seen 8's long ago as it was a soft leaver w/1.76 low. Needed more SLR
If I were and engine builder and could not produce big #'s I'd blame the dyno too...
remember the race is to the finish line, my old junk is STILL the quickest/fastest W5 on moparts.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: MegaDart] #24168
05/11/06 08:34 AM
05/11/06 08:34 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Whoptee [Edited by Moparts - Keep it clean] do.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Most Powerfull 59 Degree Small Block Ever? [Re: BBR] #24169
05/11/06 09:51 AM
05/11/06 09:51 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I believe what Ryan was trying to say was. Based on the Moroso speed calculator this was the most powerful SB combo he had heard of. That the Moroso calculator could effectively be used as a BENCHMARK by which to compare all motors. A standard so to speak. I can see the value in this. I does make sense to me. I can see how this could be skewed by chassis varibles. But it is better than trying to get all engines on the same dyno on the same day. Jim
Re: Most Powerfull 59 Degree Small Block Ever? [Re: rt66jim] #24170
05/11/06 11:46 AM
05/11/06 11:46 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
soooo you're claiming a .99 60' from a car that ran 1.7xs ? Not to mention it is as light as a go-kart.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: MegaDart] #24171
05/11/06 11:49 AM
05/11/06 11:49 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Yep. I don't think anyone ever claimed to have a faster or quicker W5 car than yours, at least on this board. I have seen a very light Sundance tube chassis run in the 8's with 5's NA. And looking at the MPH and weight in the calculator your old 422 W5 was the most powerfull one I have seen on this board as well. I don't think anyone ever disputed that, and I don't know why you are so defensive about it. Maybe someone said something to you about it in the past that I don't know about... Dunno. It certainly should have made power, it's big inch, big head, sheetmetal intake, dry sump and injected methanol. I'd be disapointed if it did'nt make power. I'm just stating that based on weight and MPH it probably is'nt the most powerfull 59* motor out there, it's pretty darn close but.. I'm looking for the best, not the closest. So hopefully you feel better now that you've heard me say that it is probably the most powerfull W5 motor I've seen to date. I guess that is what you wanted to hear
Rt66Jim pretty much summed up the intent of the post, much better than I could have.
So back to our regularly shceduled post..... any takers Weight/MPH with Quick 59* motors?
Re: Most Powerfull 59 Degree Small Block Ever? [Re: rt66jim] #24172
05/11/06 11:51 AM
05/11/06 11:51 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Ryan have you seen where the Moroso calculator is accurate through out the scale or does it have a window of accuracy?
Re: Most Powerfull 59 Degree Small Block Ever? [Re: SB412DUSTER] #24173
05/11/06 12:32 PM
05/11/06 12:32 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Ryan Ryan Ryan
I could not disagree more with this logic.
comparing my car ( leaf springs dot tires exhaust ) to a gutted out bracket car ( 4 link or ladders big tires trans brake sealed carb to hood etc.
Is just as bad as comparing one dyno to another.
Its apples and oranges
Also i have never had my car at a track with a DA less than like a 1800 ft.
Dyno #'s are corrected If I were to take my car down to maryland where 440Jim runs in the spring or fall when its 50* at sea level with a high barometer im sure i could pick up several tenths if not more not to pick on Jim by any means but he will tell you what a differnce it makes running at the mopar nats or norwalk compared to his home track. Its several tenths or more.
Does that dudes car run 9.40s on a 40* day with a 35mph tail wind one time or does it run that # year round??????/
Also I had my car out last week and it went a 136.75 mph at 3200lbs no change in ET's but more MPH i think because it spun the tires.
I think its hard to compare anyones car to another to many diffs.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: 340RICK] #24174
05/11/06 01:05 PM
05/11/06 01:05 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
that's why the calculator uses MPH, not ET. chassis setup shouldn't affect MPH too much. they'll kill your launch, which affects etc. try it next time you're at a test & tune by varying your launch. go for a hard launch, then a light launch...you're ET might vary widely, but your MPH will probably be very close.
Ryan- I'd assume then that the moroso calculator is actually calculating power to the pavement, not flywheel HP? or does it have some algorithm in it to accomodate drivetrain loss, at which case, then it looses accuracy, as a manual trans probably has a good 15-20HP efficiency gain over a 904, which has a good 15-20hp efficiency gain over a 727....
2017 Grand Cherokee Overland
Re: Most Powerfull 59 Degree Small Block Ever? [Re: patrick] #24175
05/11/06 01:37 PM
05/11/06 01:37 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That's been my experience.... soft launches vs. hard launches, and even some gearing changes, that had a big impact on ET still ran extremely close (if not identical) MPH.
All I know is Dwayne Porter's dyno also seems to be fairly consistent with the Moroso calculator, whereas another dyno I used previously probably showed an easy 10% above what the Moroso calculator comes up with.
3700#s and 122.5 MPH = ??? HP... somewhere around 520, maybe? Would have probably made around 540 HP on Dwayne's dyno (no accessories and open exhaust, vs. run in the car w/ full exhaust system, etc.), yet made 590+ HP on the other dyno.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: BradH] #24176
05/11/06 02:01 PM
05/11/06 02:01 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
cbk, who said anything about 1.7xs???
go carts weigh 500lbs, the tbucket was 1800.
Have you even made a pass in your car yet?? I know, I know, your still getting used to it right
Ryan, you knew where this thread would go.
I am a bracket racer, in fact I would race my lawnmower if my neighbor called me out...
Your title is/was a challenge to me anyone with a fast 59* motor. I'm proud of this one because I owned it and practically resurrected it from the grave. It was the [Edited by Moparts - Keep it clean] stepchild that no one wanted, full of cement and all. I gambled and it paid off.
I hope the peanut gallery is good at something cause they are terrible bench racers
I completely forgot some important data I gathered 3 years ago. When I was trying to dial in the fuel injection I put the car on a chassis dyno. Unfortunately I lost that stuff in the move but will have the info from the pulls early next week.
So what % should we use for drivetrain loss?
IIRC, this should get interesting...
Re: Most Powerfull 59 Degree Small Block Ever? [Re: BradH] #24177
05/11/06 02:13 PM
05/11/06 02:13 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
i want to know what i did to rile up megadart..sorry if i made ya mad in some way..i kinda thought that what moparts was about is everyone giving they're opinion about a given topic,and then that topic being open for discussion and input..we are always gonna have disagreement..thats human...and way Ok.....but geez,dude,i have never met ya,to go calling me out several times on this post kinda irks me..
there is always gonna be somebody faster,that did it "righter"and has a cooler ,nicer car..i think we all know that....get with the program or get a camaro...and for the record...you dont wanna go riling up "scott b"we have been friends since we were kids...its nice he looks out for me
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Most Powerfull 59 Degree Small Block Ever? [Re: MegaDart] #24178
05/11/06 02:45 PM
05/11/06 02:45 PM
Detroit, MI
Detroit, MI
uhhh you did
that is what the W5 pulled in a 23 tbucket 3 times before it melted the head...
But I see now you meant your dart, please be clear next time.
1800lbs is a go-kart compared to real cars...
Why does everyone bring The Haze into everything I post? Seems the only insult anyone has is that i'm afraid to bring it to the track or some ridiculous theory they pulled out of you know where. For the million time it's in pieces right now. Some of us go to college and don't have tons of time and money.
I think what Ryan's attempting is a noble cause. From a technical standpoint the car hobby in general is a mix of theoretically backed data with sloppy practices. It's a joke that Dyno's even vary by the amount they do. If industrial data was tested so sloppily we wouldn't be able to build anything without failure .
If moroso's #'s represent theoretical values backed up with empirical testing then why shouldn't we go by their chart rather than Joe backwoods's fish-scale-accurate Dyno?
Re: Most Powerfull 59 Degree Small Block Ever? [Re: CokeBottleKid] #24179
05/11/06 03:37 PM
05/11/06 03:37 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I was clear, please work on your comprehension skills.
If you need furthur explanation, 1.76 is the low gear in my glide, not 60' time, that would be more like yours...
backwoods dyno, I assure you Mr Richardson has probably forgotton more about sbm then most ever knew. He epitimizes the abscent minded professor...
Re: Most Powerfull 59 Degree Small Block Ever? [Re: MegaDart] #24180
05/11/06 04:07 PM
05/11/06 04:07 PM
Mega-man....some of us may not know who you are but I am pretty sure most of don't care anyway....The things you blurt out make no sense to any of us on here...the topic was high powered 59 deg sbm....then you bash talking about an 1800 lb go-cart or something of that matter....now as the topic was power I would bet my years salary that my edelbrock headed 59 degree sbm could twist the guts out of your W-whatever sbm......
Re: Most Powerfull 59 Degree Small Block Ever? #24181
05/11/06 05:03 PM
05/11/06 05:03 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
Sounds good to me, lets see the both of you as they say, Put up or shut up!! And I have no dog in this fight.
Ted
Re: Most Powerfull 59 Degree Small Block Ever? [Re: MegaDart] #24182
05/11/06 05:20 PM
05/11/06 05:20 PM
Detroit, MI
Detroit, MI
Actually my comprehension skills are up to par with college standards thanks for your concern though. However you have given reason to the Technical writing class i'm taking right now. We're taught to write clear and concisely. It's part of my curriculum and I thought it was a waste of time but I can see it's so we don't end up like you.
Care to make any other personal jabs? I love making fools of people in front of crowds...
Yes I see you were talking about the low gear in your chevy trans. And indeed The Haze doesn't put up big 60 fts (1.2s actually) but it has run 8.0's @ 174... what'd your fiber-glass mega-turd run? Hell whats the best in your BBC motor on a stick?
Re: Most Powerfull 59 Degree Small Block Ever? [Re: MegaDart] #24183
05/11/06 05:34 PM
05/11/06 05:34 PM
BradH Offline
BradH  Offline
FWIW, my old 422ci RIP made 741hp 635tq when first built.
Did those #s come from Bill Richardson's dyno?
Re: Most Powerfull 59 Degree Small Block Ever? [Re: CokeBottleKid] #24184
05/11/06 05:38 PM
05/11/06 05:38 PM
BradH Offline
BradH  Offline
Probably because you've gotten a lot cockier in your posts since you bought it.
Re: Most Powerfull 59 Degree Small Block Ever? [Re: SB412DUSTER] #24185
05/11/06 05:38 PM
05/11/06 05:38 PM
NY
B1duster Offline
B1duster  Offline
NY
--------- This is the red Duster I referred to earlier. SB412Duster, doesn't your car run mid 8s ? How much does it weigh ? Very nice car
Re: Most Powerfull 59 Degree Small Block Ever? [Re: BradH] #24186
05/11/06 05:52 PM
05/11/06 05:52 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
hey..i wanna know why i am getting dethroned from president of the moparts a## kicking club..when i seem to have just been elected......jeez..how about a little time in office...
1.41 best 60 foot
6.56 at 104.17
