Page 4 of 5 1 2 3 4 5
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416781
12/11/17 03:06 PM
12/11/17 03:06 PM
Penna
70satelliteguy Offline
Penna
Raff,I hope your tranny is up to the task. When I went from our 493 to 572 we started to tear up the front planetary(multiple times).This is launching off of a brake at 4500 rpm. Got a little smarter and After a bunch of A&A parts we got it to hold together. Big motor= lots of torque!
My 572 with Alum rods oil pressure is 80 cold and after a pass is down to 28-30psi at about 160-180 temp. I do have an adjustable pressure spring and single oil line that has worked fine to 7000 for the past 8 years.
Mike
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: 70satelliteguy] #2416888
12/11/17 06:24 PM
12/11/17 06:24 PM
Italy
Raffaplymouth60 Offline OP
Italy
Mike
Hi ! Thanks for the info ! i have adjusted now the screw 2 turn and oil pressure at 180f is 40 at idle and 80 at over 3000... i think is good with aluminium billet pump and single External line , i have also a dual line kit....but very hard install with stock engine mounts ... this is my trans specs : billet steel front drum , 5 gear planetary front and rear front and rear solid bands Full Manual v body .. no trans brake ..billet pistons with 4.2 lever big aluminium oil pan 5500 converter
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416890
12/11/17 06:33 PM
12/11/17 06:33 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Dude! Thanks for the video! Good luck with the 8's!
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416898
12/11/17 06:39 PM
12/11/17 06:39 PM
Turn the bypass regulator spring pressure up so it has the same amount of oil pressure as you shift it at(IE 70 lbs at 7000 RPM, 80lbs at 8000 RPM) or max RPM in high gear up twocents
I don't think I'm brave enough to run that little amount of rod bearing to crankshaft clearances even with aluminum rods cold shock I like and use the old rule of .0010 for each one inch of rod journal diameter up
In other words I would shoot for a minimum of .0024 for stock Mopar rod journal size of 2.375 and .0022 on BB Chevy rod journals. I have and like to use .0030 + oil clearances on my race motors with steel rods on either journal size with no problems at all, .0035+ on the mains realcrazy whistling AKA aside, when it comes to high RPM drag race motor looser on the bearing clearances is far better than a tiny bit to tight shruggy
IHTHs thumbs
That video looks just looks it was taken here in the U.S. shock
it must be very hard to duplicate that look over there bow up
Does Italy still have high import duties on American made cars and car parts?
I was shock at what the Aussie and Fins have to pay for are cars and parts puke
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Cab_Burge] #2417300
12/12/17 01:09 PM
12/12/17 01:09 PM
Italy
Italy
IHTHs thumbs
Hello Man ! i have .0020 rod clearance with bbc bearing 743HN , i have .0020 main clearance , now i have adjusted the pressure at 40 at idle and 75 at wot with 180f , i have single line milodon billet bump and single 12AN external line ..... im undecided if convert in dual line , yes i have a Big Shop of American Cars in Italy , yes for import parts i pay 35% of tax duties at governement and also high shipping price , fuel Gasoline at 7 usd at Gallon , lot of american cars in Italy
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2417427
12/12/17 04:33 PM
12/12/17 04:33 PM
I spent 9 months in Germany in 1968 in the Army, that assignment made me appreciate our country so much I can't say it in words up
Most people born here do not realize how well most of us in this country have it shruggy
I have sold several of my old race cars to guys over seas, one is in Finland, one is in Sweden and one is missing in action on the sly confused whistling
Dang the tax man anyways runaway
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2421445
12/20/17 02:34 PM
12/20/17 02:34 PM
Italy
Italy
Hi Guys... the incredible thing is that 572 engine run like stock engine , idle is very perfect , i think for Nitrous Camshaft specs ... is comp cams custom order
.050 duration 277-292
ADV duration 310-330
valve lift with 1.7 .834 .800
lobe sep 115 degree
installed at zero degree , piston to valve clearance was .160
compression ratio is 14:1
wit 100 octane no detonation when stop the engine
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2421450
12/20/17 02:42 PM
12/20/17 02:42 PM
Italy
Italy
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2421527
12/20/17 06:16 PM
12/20/17 06:16 PM
an8sec70cuda Offline
Very nice! I'd be scared of running only 100 octane in that motor. My 14:1 Indy headed wedge motor likes being run on VP C12. On nitrous I'd be running at least C16.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: an8sec70cuda] #2421554
12/20/17 07:44 PM
12/20/17 07:44 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
iagree C14 min. Don't ask me how I know... blush Engine sounds great though, bet it would idle a little lower than that...
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Dave Hall] #2421754
12/21/17 05:33 AM
12/21/17 05:33 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Not to appear pedantic but I think Europe uses a different way to rate octane numbers. IIRC I think 100 octane Europe is equivalent to 107 (ish) Stateside. Still not enough IMHO though.
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Dave Hall] #2421914
12/21/17 05:10 PM
12/21/17 05:10 PM
I wonder if you can legally buy and use any leaded race fuel in Europe now? work help
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Tig] #2421990
12/21/17 08:00 PM
12/21/17 08:00 PM
Italy
Italy
yep! i think 100 octane
is around 106/107 US Gasoline .. idle is around 1300 RPM
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Cab_Burge] #2421991
12/21/17 08:03 PM
12/21/17 08:03 PM
Italy
Italy
is possible buy racing Fuel in Italy ... 110 120 octane but price is very very very expensive .... around 5 USD at quart
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2422084
12/21/17 11:15 PM
12/21/17 11:15 PM
Is it legal to buy and use that race fuel on the streets? Or is it only legal at race tracks?
Do you know how much of your fuel prices are for taxes?
I was stationed in Germany in 1967-68 and G.I could buy books of 200 liter fuel coupons books at Post Exchange for right at .21 cents a gallon for regular and .23 cents a gallon for the premium gasoline. That was a little bit more expensive than I was paying for the same brand of fuel in the states in California back then shruggy
The German citizens paid between .91 cents and 95 cents a gallon for the same amount of volume in liters at the same pump shock
We where told that G.I didn't have to pay the German fuel taxes per liter that the Germans did work confused
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2422087
12/21/17 11:19 PM
12/21/17 11:19 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Hard to work out how the engine gets enough air past them butterfly's at idle, almost look closed.
Nice job Raff, sound great .
1963 Plymouth Max Wedge
1971 Barracuda
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Cab_Burge] #2422373
12/22/17 05:51 PM
12/22/17 05:51 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
As far as I know it is legal to run race fuel on the streets, at least in England. As long as the duty has been paid you're good to go. It is cost prohibitive though. Typically, at more recent exchange rates, it works out around $30.00 a US gallon.
I've never heard of anyone ever having petrol tested but Her Majesties Revenue and Customs (HMRC) do random road side checking for "red" diesel on a regular basis, red diesel is used for agricultural vehicles only and is exempt from fuel duty (tax).
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Tig] #2422403
12/22/17 06:42 PM
12/22/17 06:42 PM
Here in the U.S., thanks to our current environmental regulations, you can be fined up to $10,000.00 U.S. for using any leaded fuel on any public roads.
If the Feds, State, county or city authorities catch you using the red diesel fuel, which is exempt from road taxes here also up, on the roads they can fine and or put you in jail for that also runaway
Freedom my rear whistling
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Cab_Burge] #2422554
12/23/17 02:27 AM
12/23/17 02:27 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I have never heard that about leaded or heard anybody EVER get their gasoline tested for lead. Glad I don't live in your state.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: D-50] #2422559
12/23/17 02:40 AM
12/23/17 02:40 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Same here - I do think they now label it for off road use but no one has ever checked that I know of.
