Page 1 of 5 1 2 3 4 5
1970 Door VIN Tag #2416877
12/11/17 06:10 PM
12/11/17 06:10 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Does the door printed VIN tag on a vehicle match the month that the fender tag says it is supposed to be built in, or the actual month of the day it was built. For example if the build date on the fender tag says 929, would the door tag say September or October when the car was actually built?
Thanks,
Jeff
Re: 1970 Door VIN Tag [Re: Cuda340] #2416881
12/11/17 06:19 PM
12/11/17 06:19 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The Mylar door sticker was one of the very last items to go on the car before leaving the plant.
It shows the actual build month.
The fender tag date is not a 'supposed to', it is the SPD (scheduled production date) which is when they hoped to build the car when the order was first entered into the system.
Re: 1970 Door VIN Tag [Re: Cuda340] #2416884
12/11/17 06:22 PM
12/11/17 06:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
My 1970 Valiant is a good example, it has a SPD of 403 for April 3rd, but the door sticker shows March.
So for some reason it was built earlier than 'hoped for'.
Multiple other examples exist, some early & some late.
Re: 1970 Door VIN Tag [Re: Alaskan_TA] #2416891
12/11/17 06:34 PM
12/11/17 06:34 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Shouldn't the door tag match the VIN tag on the dash, and also the vin on the last part of the fender tag?
Re: 1970 Door VIN Tag [Re: Cuda340] #2416892
12/11/17 06:34 PM
12/11/17 06:34 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Thanks Barry! As with all things mopar, its about as clear as mud... lol
What would you do? My mylar tag is missing...
Re: 1970 Door VIN Tag [Re: 71birdJ68] #2416893
12/11/17 06:35 PM
12/11/17 06:35 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Yes the complete VIN should match the dash tag. Above it is the month and year of production on the door sticker.
Re: 1970 Door VIN Tag [Re: Cuda340] #2416894
12/11/17 06:36 PM
12/11/17 06:36 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
If I could find another example around my VIN that would really help...
Re: 1970 Door VIN Tag [Re: Cuda340] #2416895
12/11/17 06:37 PM
12/11/17 06:37 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It happens.
Yes, the VINs should match, but the month may not.
Do you have a broadcast sheet for it?
Re: 1970 Door VIN Tag [Re: Cuda340] #2416896
12/11/17 06:37 PM
12/11/17 06:37 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
No broadcast sheet.
Re: 1970 Door VIN Tag [Re: Cuda340] #2416897
12/11/17 06:38 PM
12/11/17 06:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Not really.
They were built so far out of VIN order at times that another close VIN with a date is not enough.
Re: 1970 Door VIN Tag [Re: Cuda340] #2416900
12/11/17 06:40 PM
12/11/17 06:40 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Have ESC make you a new sticker and use the SPD or if you really think it's a month off look at the date code on your K frame. Rumor is that it is the date closest to when your car was built.
Re: 1970 Door VIN Tag [Re: Morty426] #2416902
12/11/17 06:43 PM
12/11/17 06:43 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
I'll have to check the date on the K-frame. I am leaning towards October, but some of the sheetmetal stamps like on the inner fender says 9/29/69.
Re: 1970 Door VIN Tag [Re: Cuda340] #2416931
12/11/17 08:03 PM
12/11/17 08:03 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
without a broadcast sheet - plant & car model would help to answer the question
Hamtramck assembly line #1: I have info for 929 "SCHEDULED" cars built 2-days early thru 10/7 a week + late.
Lynch Rd. K-frame dates are a great clue, but it appears the same assembly procedures were not used at Hamtramck
Have you found any dated components with October dates that appear original to the car?
Re: 1970 Door VIN Tag [Re: Cuda340] #2417062
12/11/17 11:31 PM
12/11/17 11:31 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
Hi Dan, we spoke a little about the car before. 1970 Super Bee WM23V0A136175. Lynch road car. I didn’t take the car apart, and it is missing some of its original components. So it is kind of difficult to tell. I can check the k frame and possibly the wiper motor. Any other good clue areas?
The date on the k-frame is right in the center on the front correct? I’ll have to clean some paint off
Jeff
Re: 1970 Door VIN Tag [Re: Cuda340] #2417100
12/12/17 12:56 AM
12/12/17 12:56 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
That's the Federal Motor Vehicle Safety Standards (FMVSS) label and has nothing to do with a fender tag Scheduled Production Date or any broadcast sheet SPD. The date on it is the ACUTAL month and year that it rolled off the assembly line or actually left the factory headed to the dealership or lot pickup, and ALL Federally mandated safety items were installed and in place and the entire vehicle was in Federal Safety Standards compliance........"on the date above".
Re: 1970 Door VIN Tag [Re: A12] #2417160
12/12/17 02:28 AM
12/12/17 02:28 AM
WV
Little Detroit Offline
WV
what's that label called again?
Re: 1970 Door VIN Tag [Re: Cuda340] #2417175
12/12/17 03:10 AM
12/12/17 03:10 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
WM23V0A136175 w/929-SPD
OCTOBER (10-1969) twocents "In Plant/In Process" at least 2-weeks LATE
Re: 1970 Door VIN Tag [Re: Cuda340] #2417185
12/12/17 03:37 AM
12/12/17 03:37 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
One of my 70 Sixpack Bees has a SPD of 10/6/69 and the mylar sticker is 10/69
Re: 1970 Door VIN Tag [Re: 6bblgt] #2417190
12/12/17 03:57 AM
12/12/17 03:57 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
not the perfect example, but .....
Superbird RM23V0A171644 w/B30-SPD ("restored" in the '90s w/~60K miles on it)
based on the assigned VIN sequence it should have had a C01-SPD
all believed to be original to the car:
power steering box casting date 9299 = Monday 9/29/69
LH lower control arm stamped 301/921 = 301st day, Tuesday 10/28/69 (shift 2 line 1)
K-frame stamped 3229 1 = 322nd day, Tuesday 11/18/69 (shift 1)
car arrived at Clairpointe from Lynch Rd. Friday 11/28/69
car left Clairpointe Monday 12/1/69
Brennan Cook - SUPERBIRD pages
door sticker 12/69
Re: 1970 Door VIN Tag [Re: 6bblgt] #2417192
12/12/17 04:26 AM
12/12/17 04:26 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
door sticker 12/69
That is very interesting that the sticker reflects when it left Clairpointe rather than Lynch Rd. Would never have guessed that.
