Re: 1970 Door VIN Tag
[Re: 71birdJ68]
#2416893
12/11/17 06:35 PM
12/11/17 06:35 PM
Posts: 2,363 Wheatfield, NY
Cuda340
Wheatfield, NY
Shouldn't the door tag match the VIN tag on the dash, and also the vin on the last part of the fender tag? Yes the complete VIN should match the dash tag. Above it is the month and year of production on the door sticker.
[Re: Cuda340]
#2416897
12/11/17 06:38 PM
12/11/17 06:38 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
If I could find another example around my VIN that would really help... Not really. They were built so far out of VIN order at times that another close VIN with a date is not enough.
[Re: Cuda340]
#2416900
12/11/17 06:40 PM
12/11/17 06:40 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Thanks Barry! As with all things mopar, its about as clear as mud... lol
What would you do? My mylar tag is missing... Have ESC make you a new sticker and use the SPD or if you really think it's a month off look at the date code on your K frame. Rumor is that it is the date closest to when your car was built.
[Re: Morty426]
#2416902
12/11/17 06:43 PM
12/11/17 06:43 PM
Cuda340
Wheatfield, NY
What would you do? My mylar tag is missing... Have ESC make you a new sticker and use the SPD or if you really think it's a month off look at the date code on your K frame. Rumor is that it is the date closest to when your car was built. I'll have to check the date on the K-frame. I am leaning towards October, but some of the sheetmetal stamps like on the inner fender says 9/29/69.
[Re: Cuda340]
#2417062
12/11/17 11:31 PM
12/11/17 11:31 PM
Cuda340
Wheatfield, NY
Hi Dan, we spoke a little about the car before. 1970 Super Bee WM23V0A136175. Lynch road car. I didn’t take the car apart, and it is missing some of its original components. So it is kind of difficult to tell. I can check the k frame and possibly the wiper motor. Any other good clue areas?
The date on the k-frame is right in the center on the front correct? I’ll have to clean some paint off
Jeff
[Re: Cuda340]
#2417100
12/12/17 12:56 AM
12/12/17 12:56 AM
Posts: 21,495 N.E. OHIO, USA
A12
N.E. OHIO, USA
That's the Federal Motor Vehicle Safety Standards (FMVSS) label and has nothing to do with a fender tag Scheduled Production Date or any broadcast sheet SPD. The date on it is the ACUTAL month and year that it rolled off the assembly line or actually left the factory headed to the dealership or lot pickup, and ALL Federally mandated safety items were installed and in place and the entire vehicle was in Federal Safety Standards compliance........"on the date above".
[Re: Cuda340]
#2417175
12/12/17 03:10 AM
12/12/17 03:10 AM
Posts: 17,514 Las Vegas, NV
6bblgt
Las Vegas, NV
WM23V0A136175 w/929-SPD OCTOBER ( 10-1969) "In Plant/In Process" at least 2-weeks LATE
[Re: 6bblgt]
#2417190
12/12/17 03:57 AM
12/12/17 03:57 AM
6bblgt
Las Vegas, NV
not the perfect example, but ..... Superbird RM23V0A171644 w/B30-SPD ("restored" in the '90s w/~60K miles on it) based on the assigned VIN sequence it should have had a C01-SPD all believed to be original to the car: power steering box casting date 9299 = Monday 9/29/69 LH lower control arm stamped 301/921 = 301st day, Tuesday 10/28/69 (shift 2 line 1) K-frame stamped 3229 1 = 322nd day, Tuesday 11/18/69 (shift 1) car arrived at Clairpointe from Lynch Rd. Friday 11/28/69 car left Clairpointe Monday 12/1/69 Brennan Cook - SUPERBIRD pages door sticker 12/69
[Re: 6bblgt]
#2417192
12/12/17 04:26 AM
12/12/17 04:26 AM
Morty426
Sacramento CA
not the perfect example, but ..... Superbird RM23V0A171644 w/B30-SPD ("restored" in the '90s w/~60K miles on it) all believed to be original to the car: power steering box casting date 9299 = Monday 9/29/69 LH lower control arm stamped 301/921 = 301st day, Tuesday 10/28/69 (shift 2 line 1) K-frame stamped 3229 1 = 322nd day, Tuesday 11/18/69 (shift 1) car arrived at Clairpointe from Lynch Rd. Friday 11/28/69 car left Clairpointe Monday 12/1/69 Brennan Cook - SUPERBIRD pages door sticker 12/69 That is very interesting that the sticker reflects when it left Clairpointe rather than Lynch Rd. Would never have guessed that.
