Is bumping an engine hard on the starter Drive? #2416778
12/11/17 03:01 PM
12/11/17 03:01 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
When lashing valves I usually turn the engine with a wrench. I have used a remote starter button to bump the engine over before, but I have been concerned that it's beating up the starter drive and ring gear. Possibly leading to a failure at the worst possible moment. What's your experience with this? Am I being overly paranoid?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Is bumping an engine hard on the starter Drive? [Re: Hemi_Joel] #2416779
12/11/17 03:05 PM
12/11/17 03:05 PM
Washington
madscientist Offline
Washington
Way overly paranoid. If your starter can't take bumping to set valve lash that thing is junk.
Re: Is bumping an engine hard on the starter Drive? [Re: Hemi_Joel] #2416784
12/11/17 03:21 PM
12/11/17 03:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its no different than just starting the engine
that has a real good ignition where it wants
to start real quick.. long crank times are
harder on it than a short hit
wave
Re: Is bumping an engine hard on the starter Drive? [Re: Hemi_Joel] #2416792
12/11/17 03:41 PM
12/11/17 03:41 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Joel, since you have a Hemi and easy access to plugs, you can just pull a few to alleviate any concerns.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Is bumping an engine hard on the starter Drive? [Re: Hemi_Joel] #2416801
12/11/17 03:59 PM
12/11/17 03:59 PM
Minnesota
Minnesota
Ok, bumpity bump it shall be.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Is bumping an engine hard on the starter Drive? [Re: Hemi_Joel] #2416815
12/11/17 04:24 PM
12/11/17 04:24 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I always do it by hand. That way I hit the marks perfectly without going too far. I usually pull the plugs too, nice to have a look at them anyway.
Sheldon
Re: Is bumping an engine hard on the starter Drive? [Re: Hemi_Joel] #2416823
12/11/17 04:37 PM
12/11/17 04:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I prefer the NON lazy wrench method cos starters are designed to start your car not set valves although many do.........Plus, the wrench is more accurate since you control it............ beer
Re: Is bumping an engine hard on the starter Drive? [Re: Thumperdart] #2416838
12/11/17 05:15 PM
12/11/17 05:15 PM
fullmetaljacket Offline
Same here as Thumper said, I like to first start the engine but just for a few minutes to not create heat and just get the cylinder walls and all else coated with a nice film of oil. Then I go to the wrench on the balance bolt and turn it to the desired position for lashing without scouring the walls with dry piston drag. I like lashing them cold.
Re: Is bumping an engine hard on the starter Drive? [Re: Hemi_Joel] #2416843
12/11/17 05:20 PM
12/11/17 05:20 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
If you ever took apart an old Mopar starter you'd have a visual answer to your question. The solenoid contacts are what really take the beating and arc out with every contact. So when the starter finally fails its got nothing to do with the armature, brushes, etc, its the solenoid contacts that have bit the bullet. Ford got it right making a stand alone starter solenoid !! Easy to change and a fraction of the cost !!
Re: Is bumping an engine hard on the starter Drive? [Re: Stanton] #2416849
12/11/17 05:30 PM
12/11/17 05:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the starter to get most of the turn then
do it with a ratchet to get it on the money..
no plugs in it
wave
Re: Is bumping an engine hard on the starter Drive? [Re: MR_P_BODY] #2416906
12/11/17 06:49 PM
12/11/17 06:49 PM
I do it both ways depending on how hard it is to get the socket and breaker bar on the crankshaft bolt shruggy
I wouldn't try using the starter with all the plugs out shruggy
Re: Is bumping an engine hard on the starter Drive? [Re: Hemi_Joel] #2416967
12/11/17 08:50 PM
12/11/17 08:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I've always just bumped the starter, I even have a starter button on the center of the firewall that I can reach from both sides. I use the 'ICE' method so once they're set I can buzz through them in a few minutes just to check them.
Re: Is bumping an engine hard on the starter Drive? [Re: Hemi_Joel] #2417029
12/11/17 10:37 PM
12/11/17 10:37 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
'ICE' method?
Re: Is bumping an engine hard on the starter Drive? [Re: rowin4] #2417031
12/11/17 10:40 PM
12/11/17 10:40 PM
Originally Posted By rowin4
'ICE' method?
Intake valves start to open set the exhaust valve lash, rotate the motor over clockwise facing the motor until the intake valve opens all the way and starts to close a little and then set the exhaust valve lash scope up
Works good, last a long time thumbs wrench
Re: Is bumping an engine hard on the starter Drive? [Re: Hemi_Joel] #2417074
12/11/17 11:58 PM
12/11/17 11:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I bump mine (15-1 comp) and do not follow the firing order. Switch is right on the firewall. Same stock Dodge truck starter for 5 years. Nearly 500 passes lashed every 20-25 passes.
Doug
Re: Is bumping an engine hard on the starter Drive? [Re: dvw] #2417078
12/12/17 12:03 AM
12/12/17 12:03 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I mounted a remote switch on both sides of the firewall on my Duster and have always used the starter to set valves.
https://shop.advanceautoparts.com/p/auto...=starter+button
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Is bumping an engine hard on the starter Drive? [Re: Hemi_Joel] #2417079
12/12/17 12:06 AM
12/12/17 12:06 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yep, Bump away. up
Re: Is bumping an engine hard on the starter Drive? [Re: Hemi_Joel] #2417557
12/12/17 08:33 PM
12/12/17 08:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I always bump it with the starter. Its just hard to turn mine by hand with my mechanical fan as I always seem to bang my hands up when doing it with a breaker bar. Ron
