Page 3 of 5 1 2 3 4 5
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416489
12/10/17 10:48 PM
12/10/17 10:48 PM
Italy
Raffaplymouth60 Offline OP
Italy
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416490
12/10/17 10:50 PM
12/10/17 10:50 PM
Italy
Italy
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416492
12/10/17 10:54 PM
12/10/17 10:54 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Looks like a runner. I hope it makes the power you expect.
Good luck from Kentucky
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416499
12/10/17 11:08 PM
12/10/17 11:08 PM
Italy
Italy
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416501
12/10/17 11:13 PM
12/10/17 11:13 PM
Italy
Italy
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416537
12/10/17 11:58 PM
12/10/17 11:58 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Looking Good Raffa !!!! smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416548
12/11/17 12:13 AM
12/11/17 12:13 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That is a very nice looking engine along with a nice looking garage and other toys in there. up
Your engine compartment looks great but if you want a better looking upper radiator hose, look into the Dayco #71654.
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: ProSport] #2416568
12/11/17 12:40 AM
12/11/17 12:40 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Like how you did the exhaust.
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416575
12/11/17 12:50 AM
12/11/17 12:50 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Looks great! How about a start up video? up
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Dave Hall] #2416580
12/11/17 01:08 AM
12/11/17 01:08 AM
Mo.
racerx Offline
racerx  Offline
Mo.
With a walk around wave
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: racerx] #2416603
12/11/17 01:50 AM
12/11/17 01:50 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I want it with Surround Sound!
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416689
12/11/17 11:22 AM
12/11/17 11:22 AM
Italy
Italy
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416691
12/11/17 11:32 AM
12/11/17 11:32 AM
Italy
Italy
hello Guys ! i have some question on oil pressure ...
oil pressure is :
cold engine idle 1350 rpm 65 psi rev over 3000 85 psi
warm engine idle 1350 rpm 25 psi rev over 3000 55 psi
in my old 496 was at 75-80 psi also at warm engine at wot
Remember ... i have _Milodon billet oil pump with external single line and GRP aluminium rod with rod clearance .0019"
i have restrictor of .040 on heads with TD rockers , the gauge pointer at warm engine at wot make a vibration at 55 psi
oil weight is Valvoline 10w60 Racing
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416709
12/11/17 12:12 PM
12/11/17 12:12 PM
Penna
70satelliteguy Offline
Penna
Raff, what size headers did you end up using and what weight is your Cuda? Do you know what those -1 Indy heads flow?
That car is beautiful!!
Thanks mike
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: 70satelliteguy] #2416712
12/11/17 12:23 PM
12/11/17 12:23 PM
Italy
Italy
Thanks mike
2 1/4 headers , indy 440-1 flow is 365 cfm , weight is 3800 LB , with 496 old engine best ET was 9.2 ... my goal is 8.8 !!
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416713
12/11/17 12:29 PM
12/11/17 12:29 PM
Italy
Italy
oil pressure is :
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416717
12/11/17 12:38 PM
12/11/17 12:38 PM
Penna
Penna
"with 496 old engine best ET was 9.2 ... my goal is 8.8 !! "
Raff Was the ET with the 496 on motor or with NOS?
Mike
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: Raffaplymouth60] #2416735
12/11/17 01:30 PM
12/11/17 01:30 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
oil pressure is :
55 lbs is enough,however I would think it would be higher too.
Relief spring adjustable?
How warm is warm temp. wise.?
Maybe try another oil filter just out of curiosity twocents
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: 70satelliteguy] #2416760
12/11/17 02:18 PM
12/11/17 02:18 PM
Italy
Italy
Mike
9.2@150 mph with 496 indy 295 ported and 350 HP of nitrous with progressive controller , 727 with launch in 2nd 250 hp in 60ft and 350 after 2.5 sec
Re: Mopar RB 572 1000 HP Project 1970 Cuda [Re: 6bblFLASH] #2416761
12/11/17 02:19 PM
12/11/17 02:19 PM
Italy
Italy
oil pressure is :
yes relief is adjustable with screw , warm temp is 180f, oil filter already changed
