I'll try to answer each reply, the 3 connectors are new, never saw the old ones. Engine runs fine after warm up, won't idle up on start, let off the gas it dies. Got the idle comp ordered, maybe that's bad, has a whistle till warm. Going by the dealer to see if they'll make a printout of the wiring diagram ( I'm good friends with the parts department head guy). Got a code about some hose off, looking for that now. If the wires are right I'll go back and solder each then shrink rap them. He had bought a new coil and it was just hanging by the wires, gives you an idea what I'm dealing with.
Thanks for the help
5.9 engine
Edited by cudaman1969 (12/07/17 01:47 PM)
