Page 2 of 3 1 2 3
Re: Broke my K Frame [Re: astjp2] #2406602
11/21/17 12:27 AM
11/21/17 12:27 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Originally Posted By astjp2
When you pull the kframe, take it to a machine shop and have it hot tanked, less things to burn when welding. Tim
That's one of the reasons I have my own hot tank, but I really need to clean it out soon.
Re: Broke my K Frame [Re: astjp2] #2407193
11/22/17 02:11 AM
11/22/17 02:11 AM
California
mickm Offline OP
mickm  Offline OP
California
Good advice, but won't need to. It was well cleaned out when I put it in, had it powder coated before going in.
Will just have to clean it well for welding.
Re: Broke my K Frame [Re: mickm] #2407194
11/22/17 02:13 AM
11/22/17 02:13 AM
California
mickm Offline OP
mickm  Offline OP
California
Got down under the car today, and it is an ugly sight. The outboard side of the perch still looks like it is attached to the k frame, although a little hard to tell. The inboard side is completely separated from the frame, and bent down towards the engine, at least a few inches out of place.
So I'm going to have to bend it back into shape before it can be welded on. I may remove it and add a little structural bracing, just to be sure. Bent metal is bent metal...
I hope to have it out in the next few weeks, but we'll see...
Re: Broke my K Frame [Re: mickm] #2407613
11/22/17 11:23 PM
11/22/17 11:23 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Mick, if you need to replace the K-member, you want a good rust-free one. Let me know - I have a few contacts still from TX. & AZ. that should have some good 1970 K-members. From the way you describe it, I would not even bother trying to repair it.
Re: Broke my K Frame [Re: Sunroofcuda] #2412890
12/04/17 12:47 AM
12/04/17 12:47 AM
California
mickm Offline OP
mickm  Offline OP
California
Well, got started this weekend.
Now, you have your high tech way of doing things, and then you have your "whatever is laying around the garage" way of doing things.
I thought about buying a lift thingy that was only $60 shipped, but then I thought that after that it would just be sitting around, taking up space and collecting dust.
So, a few 4x4's, 2x4's and some chain, and here it is!
The perch is completely separated from the k frame. Don't have it out yet, but close. Wow! Busted that thing right off.
On another note, it's been a long time, and I don't have anything specific. How do I get the torsion bars out? And yes, all of the preload is off.
Re: Broke my K Frame [Re: mickm] #2412913
12/04/17 02:13 AM
12/04/17 02:13 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
You should be able to remove the balloon seal and the clip and slide them back. Might take a little jacking on the lower control arm. Very slight to get it to line up. I changed the torsion bars on my Dart and seems like someone had an oil filter wrench type tool for grabbing the thing and then hammering. Fasten the tool towards the rear X member so you can swing at it. I forget now... Anyone?
Re: Broke my K Frame [Re: mickm] #2412915
12/04/17 02:15 AM
12/04/17 02:15 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Several ways to get the torsion bars out. One way is to use the control are to push the whole thing out. I have also use two u-bolts to clamp a piece of channel iron so that I had something to hit to knock them out.
Re: Broke my K Frame [Re: mickm] #2412976
12/04/17 10:19 AM
12/04/17 10:19 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Just removed mine over the weekend. Support the LCA's w/a jack, loosen both LCA pivot nuts, back off the height adjusters, and give the LCA's a whack w/hammer and block of wood rearward. The bars should pop right out.
Re: Broke my K Frame [Re: mickm] #2413530
12/05/17 12:56 PM
12/05/17 12:56 PM
Los Osos, Ca
CKessel Online content
CKessel  Online Content
Los Osos, Ca
Watch my video on YouTube about t-bar removal. The one by Roll Another One Fabrications.
Carl Kessel
Re: Broke my K Frame [Re: astjp2] #2413786
12/05/17 08:05 PM
12/05/17 08:05 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Good luck finding a machine shop with a hot tank in California.
Re: Broke my K Frame [Re: mickm] #2413787
12/05/17 08:07 PM
12/05/17 08:07 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I would highly recommend replacing the whole thing with the proper Hemi K frame
Re: Broke my K Frame [Re: Morty426] #2413870
12/05/17 10:33 PM
12/05/17 10:33 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
This. Mega Parts will set you up. It will place the engine perfectly in the engine compartment.
Re: Broke my K Frame [Re: Morty426] #2413903
12/05/17 11:19 PM
12/05/17 11:19 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
iagree
Your Hemi puts out a lot of power. Too much for a 383 K Frame. You don't want to do this a second time.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Broke my K Frame [Re: mickm] #2414050
12/06/17 03:36 AM
12/06/17 03:36 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You guys have a stockpile of these rare 1970 only K members? From what I understand, the 1970 model is unique, the 71-71 fits but the steering box mounts are angled slightly.
Re: Broke my K Frame [Re: Pntastar69] #2414056
12/06/17 04:24 AM
12/06/17 04:24 AM
California
mickm Offline OP
mickm  Offline OP
California
That worked well for the right side, left side I can't move at all. I've triple checked that all nuts are loose, clip is out at the back, but it just doesn't want to move. I put these bars in about 10 years ago, and the car hasn't seen weather, no rust or anything, but something is keeping that LCA from moving, or the bar from coming out.
Re: Broke my K Frame [Re: CKessel] #2414058
12/06/17 04:26 AM
12/06/17 04:26 AM
California
mickm Offline OP
mickm  Offline OP
California
I did check this out. I played with moving the adjuster up and down, didn't help, although I didn't work it up and down and find the middle point. I'll try that.
Re: Broke my K Frame [Re: mickm] #2414140
12/06/17 12:44 PM
12/06/17 12:44 PM
Los Osos, Ca
Los Osos, Ca
You need to get the pressure off the hexes of the bar and the sockets, then they should slide out. Factory bars have a bit of a helix/twist in the hex which helps to keep them in. Think of it as a fastener stuck in your socket, after putting some grunt to it, that you have to change the rotation back the other way for it to pop loose. Loosening up the control arm shaft nut, say a little less than 1/4", then thumping it back gets it unstuck from the k and helps it to rotate freely to further aid getting the bars free.
Carl Kessel
Re: Broke my K Frame [Re: mickm] #2414146
12/06/17 12:57 PM
12/06/17 12:57 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
Try jacking up the LCA a bit more. You gotta find the sweet spot where it will slide out.
Re: Broke my K Frame [Re: Kern Dog] #2414155
12/06/17 01:17 PM
12/06/17 01:17 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I purchased a 1970 Hemi K-frame from Mega Parts. They take a small or big block frame and cut the mount perches off and weld HEMI perches on. They use a jig so the dimensions are spot on. They are usually made to order so don't let the out of stock keep you from calling in. Sometimes they will require a core to be sent in. http://www.megapartsusa.com/proddetail.asp?prod=MP-HKF103
Re: Broke my K Frame [Re: mickm] #2414472
12/06/17 11:34 PM
12/06/17 11:34 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Oh, okay. Thank you for the response.
Page 2 of 3 1 2 3
