#2413748 - 12/05/17 04:18 PM 1983 Lean Burn
Redbaron314 Offline
Loc: Michigan
I have a 1983 Chrysler Cordoba with a 318 lean burn 2bbl. I am not looking to delete it just yet so I am trying to troubleshoot and repair at the moment. So when I am trying to drive the car I have to barley press on the pedal or it falls flat on it nose and what sounds like pops through the carb. it has a Complete tune up recently done, timing verified with a timing light, new fuel filter and pump.
#2413793 - 12/05/17 05:18 PM Re: 1983 Lean Burn [Re: Redbaron314]
Diplomat360 Offline
Loc: Windsor, ON, Canada
Man, that's a tough one...it's been years now since I've worked with the LB stuff, but with the car parked (shift selector in P or N) and timing light hooked up, what happens to the timing when you take it off idle???
The LB computer is programmed to control the timing once the carb comes off idle setting. I am thinking of this simple test as a way to at least determine if the LB computer is the problem, or maybe something else?
If the timing jumps (could advance, or it could retard) then the LB box is probably not the culprit, because the change in timing would indicate the LB ECU is reacting to the change...mind you, it could of course be reacting incorrectly...grrhh....
1980 Dodge Diplomat Coupe, 360-4bbl, 727, 3.91 SG motivated sleeper! 1981 Dodge Diplomat Coupe, /6 38K mi. survivor car, awaiting restoration.
#2413796 - 12/05/17 05:22 PM Re: 1983 Lean Burn [Re: Redbaron314]
Supercuda Offline
Sounds like the accelerator pump in the carb is bad. I'd check that before I got all worked up about the LB.
#2413822 - 12/05/17 06:02 PM Re: 1983 Lean Burn [Re: Redbaron314]
Redbaron314 Offline
Loc: Michigan
Ok, thank you for the advice on my tricky situation. Now I have been hearing all over just buy the lean burn delete kit and so far before I remove all my hair that might be the best option. Problem being I cannot find this kit......
#2413824 - 12/05/17 06:05 PM Re: 1983 Lean Burn [Re: Redbaron314]
Supercuda Offline
There is no kit, per se.
You replace the carb with a non-lean burn one and put an electronic ignition conversion kit in
http://www.manciniracing.com/ma27331834033.html
#2413830 - 12/05/17 06:15 PM Re: 1983 Lean Burn [Re: Supercuda]
DarrenS Offline
Loc: Courtenay, B.C.
I'd agree not to get worked up. Most problems I've had with lb cars have been attributable to the standard stuff (vacuum leaks and carb or ignition problems).
I would not just swap it all out unless you wanted to start upgrading everything for performance...
#2413835 - 12/05/17 06:30 PM Re: 1983 Lean Burn [Re: DarrenS]
Loc: Lincoln Nebraska
What Supercuda & Darren said, check the squirt for immediate tip in/quantity then if good I would search for a vac leak.
#2413846 - 12/05/17 06:54 PM Re: 1983 Lean Burn [Re: Redbaron314]
Redbaron314 Offline
Loc: Michigan
ok, and ty for the lb delete info also
#2416183 - 12/10/17 11:24 AM Re: 1983 Lean Burn [Re: Redbaron314]
DynoDave Offline
Loc: MICHIGAN
Certainly have to check the basics, like accelerator pump shot, before moving on.
I'm not as familiar with the later system...have worked on '77 and '78 models. But they used a ground wire on the throttle stop so the system knows when the throttle is closed. Also, they have a throttle position transducer (TPS in modern terms). If accelerator pump action seems good, checking the condition of these may help. The computer can't react if it doesn't know the throttle is moving.
If you have a set of '83 factory service manuals, they're sure to be of help. If you don't have a set, and get stuck, let me know. I have a set, and can check through the diagnostics for you, post some photos of those pages, etc.
DynoDave
WPC #12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
http://wichargerguy.proboards.com/
#2417165 - 12/11/17 11:52 PM Re: 1983 Lean Burn [Re: Redbaron314]
Diplomat360 Offline
Given the OP's comment below:
Originally Posted By Redbaron314
...it has a Complete tune up recently done, timing verified with a timing light, new fuel filter and pump...
...I honestly can not even imagine such a tune-up not covering something as basic as Carb 101: is the accel pump working? is it providing good enough volume of fuel? etc, etc.
But anyways...so my feedback is based on personal experience with different LB computers, specifically the timing differences programmed in on a 2 bbl vs 4 bbl setup.
In my case (many many years ago, so memory is a little faint) I picked up a 4 bbl setup at a swap meet. Given that I just installed my first 4 bbl carb (Carter TQ) I thought this would have been a great improvement. Well, something was probably wrong with that LB module because that very night I took the car out I had a massive backfire after a WOT run which literally blew off the muffler...LOL, yeah, impressed all my buddies, but gave me a busted exhaust pipe.
Sooo...off I went digging into the specs and all that, eventually found out that the 4 bbl unit did have a different timing amount (initial, off-throttle and vac-advance) that would have been the right move for my setup had it worked correctly. Who's to tell if I simply missed an additional input of some sorts though...I studied that darn hook-ups, but was just cutting my "teeth" on LB era Mopars at the same time.
Anyways, like I said, for what it's worth given my hands-on experience.
#2417217 - 12/12/17 05:11 AM Re: 1983 Lean Burn [Re: Redbaron314]
rumblebee4232 Offline
Loc: Stinnett, Tx
Did the car sit for a while?? Is the fuel old?? I had one that acted like you are describing(not lean burn) and it turned out that there was water in the carburetor.. cleaned it out and it ran like new again..
25,382 Registered Members
190,978 Topics
Haven't posted in awhile...My 70 Bee with wheel covers
by Florida_70Bee
07/20/18 10:38 PM
1966 Coronet 500 - Upper Door Frame Color??
by FastbackJon
07/20/18 10:19 PM
Gen3 vs Big Block - Mid-Plate to Front Motor Plate: Measured
by moparmitch
07/20/18 10:12 PM
Blow it out your ___
by EV2Bird
07/20/18 09:45 PM
