Question when does the streetcar turn into a drag car NHRA #2413393
12/05/17 01:58 AM
12/05/17 01:58 AM
CA.
RAY1969CARS Offline OP
CA.
When dosNHRA rules say a street car Turned into a drag car rules ???
Is it elapsed time or what the cars equipped with nitrous blower turbos
http://www.irwindalespeedway.com/dragstrip/street_rules.html
Thanks guys Mopar or no car
Re: Question when does the streetcar turn into a drag car NHRA [Re: RAY1969CARS] #2413396
12/05/17 02:03 AM
12/05/17 02:03 AM
I think the current "race car rules" identification starts at quicker than 11.49 in the 1/4 mile, I don't remember the 1/8 mile times shruggy
That link was dated in 2012, long before the 11.49 rule was adjusted down from 11.99 ET and quicker ET for roll bars and shoulder harnesses.
Re: Question when does the streetcar turn into a drag car NHRA [Re: RAY1969CARS] #2413402
12/05/17 02:10 AM
12/05/17 02:10 AM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
They don't care if it has tags or not. Rules are determined by ET, MPH, construction, power adders, and intended class. If it doesn't fit a specific class (Super Stock, Pro Mod, Super Gas, etc.) then applicable rules should be able to be found in the E.T. and General Regulations sections.
Re: Question when does the streetcar turn into a drag car NHRA [Re: CMcAllister] #2413410
12/05/17 02:22 AM
12/05/17 02:22 AM
CA.
CA.
right on
I guess were my question lies is
I have a very mild 360 putting 100 shot of nitrous on it Drag Radial 26 x 8 I do you have a safety loop ,all my fuel lines is either braided or aluminum it’s my street car never been on the track I’ve done all the basic Street rule I do you have a jacket and a Sa 2010 Helmet
My one concern is wheel stud my one concern is wheel studs In the back I maybe have a quarter-inch showing In the front I have no thread showing Stock wheel studs With weld ProStar and through bolt lug nuts But I do you have all studs president
Trying to run at Irwindale Mooneyes Christmas show
Re: Question when does the streetcar turn into a drag car NHRA [Re: RAY1969CARS] #2413424
12/05/17 02:40 AM
12/05/17 02:40 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
For your safety and the safety of others your studs should stick though the lug nut. If the stud thread does not enter into the nut part you are basically holding the wheel on with the thin shank of the lug nut. Buying new longer studs will be a cheap alternative compared to the damage caused by the rear wheel coming off from broken studs. Studs will shear off from lug nuts loosening as the head of the nut breaks loose from the shank. Can you say quarter panel, brake parts, tire and wheel? Yes studs are a cheap alternative.
Re: Question when does the streetcar turn into a drag car NHRA [Re: RAY1969CARS] #2413425
12/05/17 02:41 AM
12/05/17 02:41 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It's a race car when you say it's a race car. up They'll only throw you out once. tsk I am not clear about drag radials and wheel studs. I'm pretty sure if you have racing slicks that the studs must show 2 threads through the nut. Also if these are racing drag radials I would recommend treating them like slicks. Axle studs and lug nuts are relatively inexpensive. If, according to tech, these radials are treated like slicks, you won't be able to run a Street or Sportsman class. Hope this helps a little.
Re: Question when does the streetcar turn into a drag car NHRA [Re: RAY1969CARS] #2413434
12/05/17 02:58 AM
12/05/17 02:58 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Aftermarket wheels can also trigger the stud rule no matter what tire you use.
Re: Question when does the streetcar turn into a drag car NHRA [Re: RAY1969CARS] #2413534
12/05/17 12:59 PM
12/05/17 12:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well that will be one of the last races ever run at Irwindale as it is closing in Jan of 2018 to become a strip mall. My suggestions is follow NHRA rules as your only other track to use will be Fontana. They are putting in lights to try and pick up some of the slack from Irwindales closing and running a Friday night program.
Re: Question when does the streetcar turn into a drag car NHRA [Re: RAY1969CARS] #2413597
12/05/17 03:18 PM
12/05/17 03:18 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Section 5:2 in the rulebook. "The thread engagement on all wheel studs to the lug nut must be equivalent to or greater than the diameter of the studs." I.E. With a 1/2" stud, the stud must be engaged in the hex portion of the nut at least 1/2".
Those thick Welds - or any other brand with the thick center - need long studs.
Drag radials will be more likely to break marginal stuff than a bias tire.
Re: Question when does the streetcar turn into a drag car NHRA [Re: CMcAllister] #2413599
12/05/17 03:22 PM
12/05/17 03:22 PM
CA.
CA.
I’ve read that but how do street class cars get away with the stud rules
Re: Question when does the streetcar turn into a drag car NHRA [Re: RAY1969CARS] #2413607
12/05/17 03:34 PM
12/05/17 03:34 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
They shouldn't!
Have a great day
Iowan
"obsolete is neat"
Re: Question when does the streetcar turn into a drag car NHRA [Re: RAY1969CARS] #2413666
12/05/17 05:13 PM
12/05/17 05:13 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
You don't necessarily need long studs. You just need the studs to stick out beyond the face of the wheel and engage the hex 1/2" or so. Thick centered aftermarket wheels mean the studs need to be longer. If you set the wheel on the studs, push it against the hub and the studs aren't sticking out of the wheel at least 1/2", it's not right.
Re: Question when does the streetcar turn into a drag car NHRA [Re: RAY1969CARS] #2413890
12/05/17 11:02 PM
12/05/17 11:02 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Every stock/street car that I've had meet this requirement with some margin without anything special.
