Question when does the streetcar turn into a drag car NHRA
#2413393
12/05/17 01:58 AM
12/05/17 01:58 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
When dosNHRA rules say a street car Turned into a drag car rules ??? Is it elapsed time or what the cars equipped with nitrous blower turbos http://www.irwindalespeedway.com/dragstrip/street_rules.htmlThanks guys Mopar or no car
Re: Question when does the streetcar turn into a drag car NHRA
[Re: RAY1969CARS]
#2413396
12/05/17 02:03 AM
12/05/17 02:03 AM
Posts: 43,206 Bend,OR USA
Cab_Burge
I think the current "race car rules" identification starts at quicker than 11.49 in the 1/4 mile, I don't remember the 1/8 mile times That link was dated in 2012, long before the 11.49 rule was adjusted down from 11.99 ET and quicker ET for roll bars and shoulder harnesses.
[Re: RAY1969CARS]
#2413402
12/05/17 02:10 AM
12/05/17 02:10 AM
Posts: 11,589 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
They don't care if it has tags or not. Rules are determined by ET, MPH, construction, power adders, and intended class. If it doesn't fit a specific class (Super Stock, Pro Mod, Super Gas, etc.) then applicable rules should be able to be found in the E.T. and General Regulations sections.
[Re: RAY1969CARS]
#2413424
12/05/17 02:40 AM
12/05/17 02:40 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
For your safety and the safety of others your studs should stick though the lug nut. If the stud thread does not enter into the nut part you are basically holding the wheel on with the thin shank of the lug nut. Buying new longer studs will be a cheap alternative compared to the damage caused by the rear wheel coming off from broken studs. Studs will shear off from lug nuts loosening as the head of the nut breaks loose from the shank. Can you say quarter panel, brake parts, tire and wheel? Yes studs are a cheap alternative.
[Re: RAY1969CARS]
#2413434
12/05/17 02:58 AM
12/05/17 02:58 AM
Posts: 20,182 Park Forest, IL
slantzilla
Park Forest, IL
Aftermarket wheels can also trigger the stud rule no matter what tire you use.
[Re: RAY1969CARS]
#2413534
12/05/17 12:59 PM
12/05/17 12:59 PM
Posts: 19,368 Las Vegas
Al_Alguire
Las Vegas
Well that will be one of the last races ever run at Irwindale as it is closing in Jan of 2018 to become a strip mall. My suggestions is follow NHRA rules as your only other track to use will be Fontana. They are putting in lights to try and pick up some of the slack from Irwindales closing and running a Friday night program.
[Re: RAY1969CARS]
#2413597
12/05/17 03:18 PM
12/05/17 03:18 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Section 5:2 in the rulebook. "The thread engagement on all wheel studs to the lug nut must be equivalent to or greater than the diameter of the studs." I.E. With a 1/2" stud, the stud must be engaged in the hex portion of the nut at least 1/2".
Those thick Welds - or any other brand with the thick center - need long studs.
Drag radials will be more likely to break marginal stuff than a bias tire.
[Re: RAY1969CARS]
#2413607
12/05/17 03:34 PM
12/05/17 03:34 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I’ve read that but how do street class cars get away with the stud rules They shouldn't!
Have a great day Iowan
"obsolete is neat"
[Re: RAY1969CARS]
#2413666
12/05/17 05:13 PM
12/05/17 05:13 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I’ve read that but how do street class cars get away with the stud rules You don't necessarily need long studs. You just need the studs to stick out beyond the face of the wheel and engage the hex 1/2" or so. Thick centered aftermarket wheels mean the studs need to be longer. If you set the wheel on the studs, push it against the hub and the studs aren't sticking out of the wheel at least 1/2", it's not right.
[Re: RAY1969CARS]
#2413890
12/05/17 11:02 PM
12/05/17 11:02 PM
Posts: 4,315 Prospect, PA
BSB67
Prospect, PA
I’ve read that but how do street class cars get away with the stud rules Every stock/street car that I've had meet this requirement with some margin without anything special.
