Re: 2001 Ram Van electrical issue
[Re: cudaman1969]
#2412485
12/02/17 11:36 PM
12/02/17 11:36 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Buy yourself a factory service manual on ebay. It will save you a lot of time trying to trace wiring and pay for itself. Look for your harness on www.car-part.com
[Re: cudaman1969]
#2414775
12/07/17 04:46 PM
12/07/17 04:46 PM
Posts: 8,250 fredericksburg,va
cudaman1969
fredericksburg,va
I'll try to answer each reply, the 3 connectors are new, never saw the old ones. Engine runs fine after warm up, won't idle up on start, let off the gas it dies. Got the idle comp ordered, maybe that's bad, has a whistle till warm. Going by the dealer to see if they'll make a printout of the wiring diagram ( I'm good friends with the parts department head guy). Got a code about some hose off, looking for that now. If the wires are right I'll go back and solder each then shrink rap them. He had bought a new coil and it was just hanging by the wires, gives you an idea what I'm dealing with. Thanks for the help 5.9 engine
[Re: cudaman1969]
#2414859
12/07/17 07:18 PM
12/07/17 07:18 PM
cudaman1969
fredericksburg,va
Throttle body is carboned up?? Shouldn't be right? got to thinking about that bottom pan on intake, leaking? ( maybe the whistle)? Put new battery in, started and ran normal cold. Chasing gremlins!
