Charger Specialties Circuit Boards
#2413025
12/04/17 12:56 PM
12/04/17 12:56 PM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
Recently I replaced the circuit boards in my Barracuda with new one from Charger Specialties. When I got everything back together, the temp and oil pressure gauges stopped working. So I pulled the dash back out and noticed a glob of solder that was touching both the bottom pins where these gauges connect. I carefully removed the glob and put it all back together. Gauges still don't work.
Has anyone has this type of problem with their boards?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Charger Specialties Circuit Boards
[Re: Erik]
#2413515
12/05/17 12:09 PM
12/05/17 12:09 PM
Erik
Stroudsburg, PA
Yes, the gauges worked before I swapped the boards.
Yes, I contacted the manufacturer who told me to test the voltage.
They did not come with instructions, but they are very simple to install.
