Charger Specialties Circuit Boards #2413025
12/04/17 12:56 PM
12/04/17 12:56 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Recently I replaced the circuit boards in my Barracuda with new one from Charger Specialties. When I got everything back together, the temp and oil pressure gauges stopped working. So I pulled the dash back out and noticed a glob of solder that was touching both the bottom pins where these gauges connect. I carefully removed the glob and put it all back together. Gauges still don't work.
Has anyone has this type of problem with their boards?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Charger Specialties Circuit Boards [Re: Erik] #2413269
12/04/17 09:47 PM
12/04/17 09:47 PM
Andrewh Offline
Andrewh  Offline
never used them.
did the gauges work before?
did you test them?
2 AA batteries in series wired to each side. they are slow to respond so give it a little bit see if they move.
Re: Charger Specialties Circuit Boards [Re: Erik] #2413274
12/04/17 09:59 PM
12/04/17 09:59 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Have you contacted the supplier with your problem to see if they can help or have any suggestions?
Re: Charger Specialties Circuit Boards [Re: Erik] #2413502
12/05/17 11:41 AM
12/05/17 11:41 AM
blewbyu Offline
blewbyu  Offline
I have one but have not installed it yet. I know there is some specific instructions did you follow them?
Re: Charger Specialties Circuit Boards [Re: Erik] #2413515
12/05/17 12:09 PM
12/05/17 12:09 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Yes, the gauges worked before I swapped the boards.
Yes, I contacted the manufacturer who told me to test the voltage.
They did not come with instructions, but they are very simple to install.
