Pick My Torque Converter #2409547
11/27/17 12:35 PM
11/27/17 12:35 PM
MassHole Central
rtman Offline OP
rtman  Offline OP
MassHole Central
Car: 1973 Satellite Sebring Plus. Figure 3500-3600 lbs
Motor: 1972 340
Compression: assume 9.5 to 1
Cam: Mopar Purple shaft, .471 lift
Trans: 904
Rear-end: 3:55 Sure Grip (8.25")
Tires: 215/60-15
Swapping out the original 318. The car will be street driven only. I have available to me (cheaply) a Turbo Action 17805ST. Would love to get it moving quickly from rest, but its a heavy car. Is this converter a good match for my combo?
It would be easier and cheaper for me to keep the Turbo Action unit. Feel free to give me your recommendations. Thanks.
Re: Pick My Torque Converter [Re: rtman] #2409583
11/27/17 01:33 PM
11/27/17 01:33 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Could do worse. That looks like a good unit. If you have a wanting to get that thing moving, with some tire spin etc, that will help.
Re: Pick My Torque Converter [Re: rtman] #2409616
11/27/17 02:48 PM
11/27/17 02:48 PM
crlush Offline
crlush  Offline
Its not a bad convertor.
Re: Pick My Torque Converter [Re: rtman] #2409623
11/27/17 02:57 PM
11/27/17 02:57 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I believe that is an 11" Converter. I have that one and it is a very good converter. It was advertised as a Street Hemi Converter.
Re: Pick My Torque Converter [Re: rtman] #2409686
11/27/17 05:18 PM
11/27/17 05:18 PM
Call turbo Action and ask them this question twocents
Did you degree the cam in the motor? If so good up
If not shruggy
Re: Pick My Torque Converter [Re: buildanother] #2409751
11/27/17 07:47 PM
11/27/17 07:47 PM
MassHole Central
rtman Offline OP
rtman  Offline OP
MassHole Central
Will it fit in a 904 vs. 727?
Re: Pick My Torque Converter [Re: rtman] #2409753
11/27/17 07:51 PM
11/27/17 07:51 PM
CA
crackedback Offline
crackedback  Offline
CA
Re: Pick My Torque Converter [Re: rtman] #2409819
11/27/17 09:58 PM
11/27/17 09:58 PM
CA
MorePower Offline
MorePower  Offline
CA
I used Edge Racing converters for all my converters. Love them. The owner gets on the phone with you and goes over your car goals and setup and helps develop the perfect custom converter just for you.
