Re: 2008 ram 5.7 auto. shifter problem
[Re: BigTerry]
#2409580
11/27/17 01:22 PM
11/27/17 01:22 PM
Posts: 8,670 Buford, GA
I_bleed_MOPAR
Buford, GA
Go into gear or to get it out of park? Did the '08 have the same problem as my '06 of the bushings in the brake pedal mount breaking apart and allowing the brake pedal to move side-to-side? I noticed that sometimes if I wasn't pushing straight down on the brake pedal that the brake lights did not come on. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: BigTerry]
#2419487
12/16/17 03:27 PM
12/16/17 03:27 PM
I_bleed_MOPAR
Buford, GA
If you haven't already figured it out, I would grab the brake pedal and see if it moves side-to-side. If it does, that may be the problem.
Tim
