Help me identify this rear end #2408072
11/24/17 12:03 AM
11/24/17 12:03 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
This rear end is in my newly acquired 37 Plymouth 2 door businessman coupe, it's got modern brakes with a Ford/Mopar 4.5 bolt circle pattern, what is it?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Help me identify this rear end [Re: AZ_A12_BEE] #2408073
11/24/17 12:04 AM
11/24/17 12:04 AM
Dreaming of the 808
Dreaming of the 808
Front
Re: Help me identify this rear end [Re: AZ_A12_BEE] #2408077
11/24/17 12:07 AM
11/24/17 12:07 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Ford 8". work
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Help me identify this rear end [Re: amxautox] #2408078
11/24/17 12:14 AM
11/24/17 12:14 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Looky like an early Oldsmobile to me.
Ford 8" are flat on the bottom + the pinion bearings have a cover on the front behind the yoke, which this doesn't have.
Re: Help me identify this rear end [Re: Neil] #2408082
11/24/17 12:19 AM
11/24/17 12:19 AM
Dreaming of the 808
Dreaming of the 808
Olds had a 4.5 inch bolt pattern?
Re: Help me identify this rear end [Re: Neil] #2408084
11/24/17 12:20 AM
11/24/17 12:20 AM
amxautox Offline
amxautox  Offline
Oh ya, forgot about the flatness. I don't know anything about any GM types.
Tom
author unknown
Re: Help me identify this rear end [Re: AZ_A12_BEE] #2408087
11/24/17 12:27 AM
11/24/17 12:27 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Not sure on the bolt pattern for cars way back then. Someone may have put other axles in it when they did the rear brake swap?
I'm not 100% sure it's an Old axle, but it looks like that more than anything else I can think of right now.
Re: Help me identify this rear end [Re: AZ_A12_BEE] #2408092
11/24/17 12:44 AM
11/24/17 12:44 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Are the ends of the axle flanges flat, or do they have a nut on the end? are the springs narrow,(like 2" wide)? It almost looks like the original 37 Plymouth rear end. That rear end was used up until 64. They were a lot like an 8 3/4 but nothing from the 65 on 8 3/4 interchanges. Gene
Re: Help me identify this rear end [Re: poorboy] #2408107
11/24/17 01:04 AM
11/24/17 01:04 AM
Dreaming of the 808
Dreaming of the 808
I will have to pull a wheel and see
Re: Help me identify this rear end [Re: Neil] #2408108
11/24/17 01:05 AM
11/24/17 01:05 AM
jersey
Spaceman Spiff Offline
jersey
Olds rears don't have a bump for the ring gear.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Help me identify this rear end [Re: Spaceman Spiff] #2408115
11/24/17 01:35 AM
11/24/17 01:35 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
These appear to have the bump in the back, and a bunch of mounting brackets that Dave's doesn't have.
https://www.ebay.com/itm/1957-58-59-60-6...tMQ&vxp=mtr
Re: Help me identify this rear end [Re: AZ_A12_BEE] #2408120
11/24/17 01:46 AM
11/24/17 01:46 AM
jersey
jersey
‘57 olds has leaf springs. Those in the picture from eBay aren’t from a leaf spring car.
Re: Help me identify this rear end [Re: Spaceman Spiff] #2408129
11/24/17 02:28 AM
11/24/17 02:28 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Here is a guy selling just the center section. It has three ribs on the drivers side and two on the passenger side with one angled up at the 10 o'clock position. Daves's rear end has too much dirt on it for me to see if the fill hole is in the same spot. Note to Dave to please wash his rear end before sharing pics please.
Tabs on the housing could have been cut off in the past. Or maybe it's not a 57-64 Olds Pontiac setup?
https://www.ebay.com/itm/3-64-DROP-OUT-V...=item3d4fe362ad
Re: Help me identify this rear end [Re: Neil] #2408138
11/24/17 03:22 AM
11/24/17 03:22 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I think that 57 58 59 and 60 Olds all used leaf springs. 57 Pontiac had leafs, but 58 through 64 Pontiac used coils, along with the 61 through 64 Oldsmobiles.
Re: Help me identify this rear end [Re: AZ_A12_BEE] #2408141
11/24/17 03:24 AM
11/24/17 03:24 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
From your other pictures the axles don't appear to be the type that have a nut holding them on.
Re: Help me identify this rear end [Re: AZ_A12_BEE] #2408142
11/24/17 03:25 AM
11/24/17 03:25 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That is a '57-'64 Olds/Pontiac rear.
Re: Help me identify this rear end [Re: DoctorDiff] #2408167
11/24/17 10:48 AM
11/24/17 10:48 AM
moparx Offline
moparx  Offline
wouldn't that have a 5" bolt pattern if the axles are stock ?
beer
Re: Help me identify this rear end [Re: moparx] #2408205
11/24/17 12:38 PM
11/24/17 12:38 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
beer
Lotsa things get tweaked in 60 years...
- Stu Harmon
Re: Help me identify this rear end [Re: feets] #2408257
11/24/17 02:44 PM
11/24/17 02:44 PM
Dreaming of the 808
Dreaming of the 808
beer
Thats for sure, I don't know how many different motors this has had over the years but guessing from all the welded on brackets or what's left of them I'm guessing at least 3 different motor set ups
Re: Help me identify this rear end [Re: AZ_A12_BEE] #2408260
11/24/17 02:57 PM
11/24/17 02:57 PM
o
ChryCoGuy Offline
ChryCoGuy  Offline
o
Found this link on the HAMB regarding bolt patterns. Don't know if it's much help to you, though.
http://www.roddingroundtable.com/tech/articles/boltpat.html
