Help me identify this rear end
#2408072
11/24/17 12:03 AM
11/24/17 12:03 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
This rear end is in my newly acquired 37 Plymouth 2 door businessman coupe, it's got modern brakes with a Ford/Mopar 4.5 bolt circle pattern, what is it?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Help me identify this rear end
[Re: Neil]
#2408082
11/24/17 12:19 AM
11/24/17 12:19 AM
AZ_A12_BEE
Dreaming of the 808
Looky like an early Oldsmobile to me.
Ford 8" are flat on the bottom + the pinion bearings have a cover on the front behind the yoke, which this doesn't have. Olds had a 4.5 inch bolt pattern?
37 Plymouth PU
[Re: Neil]
#2408084
11/24/17 12:20 AM
11/24/17 12:20 AM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Oh ya, forgot about the flatness. I don't know anything about any GM types.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: poorboy]
#2408107
11/24/17 01:04 AM
11/24/17 01:04 AM
AZ_A12_BEE
Dreaming of the 808
Are the ends of the axle flanges flat, or do they have a nut on the end? are the springs narrow,(like 2" wide)? It almost looks like the original 37 Plymouth rear end. That rear end was used up until 64. They were a lot like an 8 3/4 but nothing from the 65 on 8 3/4 interchanges. Gene I will have to pull a wheel and see
37 Plymouth PU
[Re: Neil]
#2408108
11/24/17 01:05 AM
11/24/17 01:05 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Ford 8" are flat on the bottom + the pinion bearings have a cover on the front behind the yoke, which this doesn't have. Olds rears don't have a bump for the ring gear.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: AZ_A12_BEE]
#2408120
11/24/17 01:46 AM
11/24/17 01:46 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
‘57 olds has leaf springs. Those in the picture from eBay aren’t from a leaf spring car.
[Re: Spaceman Spiff]
#2408129
11/24/17 02:28 AM
11/24/17 02:28 AM
Posts: 20,661 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Here is a guy selling just the center section. It has three ribs on the drivers side and two on the passenger side with one angled up at the 10 o'clock position. Daves's rear end has too much dirt on it for me to see if the fill hole is in the same spot. Note to Dave to please wash his rear end before sharing pics please. Tabs on the housing could have been cut off in the past. Or maybe it's not a 57-64 Olds Pontiac setup? https://www.ebay.com/itm/3-64-DROP-OUT-V...=item3d4fe362ad
[Re: Neil]
#2408138
11/24/17 03:22 AM
11/24/17 03:22 AM
Posts: 1,841 South Bend
John Brown
South Bend
I think that 57 58 59 and 60 Olds all used leaf springs. 57 Pontiac had leafs, but 58 through 64 Pontiac used coils, along with the 61 through 64 Oldsmobiles.
[Re: AZ_A12_BEE]
#2408141
11/24/17 03:24 AM
11/24/17 03:24 AM
John Brown
South Bend
From your other pictures the axles don't appear to be the type that have a nut holding them on.
[Re: moparx]
#2408205
11/24/17 12:38 PM
11/24/17 12:38 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
That is a '57-'64 Olds/Pontiac rear. wouldn't that have a 5" bolt pattern if the axles are stock ? Lotsa things get tweaked in 60 years...
[Re: feets]
#2408257
11/24/17 02:44 PM
11/24/17 02:44 PM
AZ_A12_BEE
Dreaming of the 808
That is a '57-'64 Olds/Pontiac rear. wouldn't that have a 5" bolt pattern if the axles are stock ? Lotsa things get tweaked in 60 years... Thats for sure, I don't know how many different motors this has had over the years but guessing from all the welded on brackets or what's left of them I'm guessing at least 3 different motor set ups
37 Plymouth PU
