BLOCK CLEARANCING w/bryant 4.375" crank and stock HEMI rods #2407954
11/23/17 06:23 PM
11/23/17 06:23 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hello!
I was wondering if it will be possible to clearance the bottom of the bores for a 4.375" crank with Mopar rod journal size and stock HEMI rods?
Plan on an external oil line. I am just worried about the clearacing on the bottom of the cylinder bores with the std size mopar journal and reconditioned stock HEMI rods.
BTW I am gonna be using a 4.25" bore siamese HEMI block. (the ones that have the dont bore over 4.34" warning decal on them).
Re: BLOCK CLEARANCING w/bryant 4.375" crank and stock HEMI rods [Re: domingo] #2407964
11/23/17 06:52 PM
11/23/17 06:52 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Should not be any problem at all. I have the same stroke with fat Nascar rods
Re: BLOCK CLEARANCING w/bryant 4.375" crank and stock HEMI rods [Re: domingo] #2407968
11/23/17 07:06 PM
11/23/17 07:06 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Great.
Did you have to clearance the block any more than what they come with? What block are you using?
Because the one I have already came clearanced some....
Oh well if it doesnt ill just grind away some....I was just fearing it might be too much I dont wanna ruin the block, thats why I asking of somebody is running such a setup-----
Re: BLOCK CLEARANCING w/bryant 4.375" crank and stock HEMI rods [Re: domingo] #2408079
11/24/17 12:15 AM
11/24/17 12:15 AM
I think I used the same size stroker crank(4.375) in one of those early Mopar Mega Hemi blocks with a set of Eagle 6.86 long SS rods and didn't have to grind very much off of the cam side of the cylinder walls and less on the oil pan side of the cylinder walls work I did have to grind the oil pickup boss down some also sawzall
Good luck on your deal thumbs wrench grin
Re: BLOCK CLEARANCING w/bryant 4.375" crank and stock HEMI rods [Re: domingo] #2408288
11/24/17 03:49 PM
11/24/17 03:49 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
We'll see how it goes! Ill post the pics so it ends up here in the archive in the event somebody wants to know as well in the future!!!!!
Re: BLOCK CLEARANCING w/bryant 4.375" crank and stock HEMI rods [Re: domingo] #2531259
08/03/18 11:08 PM
08/03/18 11:08 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I did have to do more clearancing on the megablock that what it came with from the factory.....but the older siamese MP megablock I used had plenty of meat there, and when i slid my finger inside the water jackets, I could feel how the tooling the used to cast this block considered this area an area where engine builders WILL have to grind on to clear strocker crank/rod combos. The water jacket has a BIG lump or iron there as opposed to a factory hemi block.
So 4.375" crank and 6,96" stock rods with BIG older ARP hex nuts were not a problem after some serious grinding and that area on the bottom of the bores still remained super thick thanks to the extra meat on these MEGABLOCK castings!
Re: BLOCK CLEARANCING w/bryant 4.375" crank and stock HEMI rods [Re: domingo] #2531287
08/03/18 11:56 PM
08/03/18 11:56 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
THanks for the update, that's good info.
BTW, the blocks with that sticker that says don't bore over 4.34, often can be bored to 4.5". YOu need to sonic test, and you might have to move a cylinder or 2 over toward the thick side to maintain sufficient wall thickness.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: BLOCK CLEARANCING w/bryant 4.375" crank and stock HEMI rods [Re: domingo] #2531290
08/04/18 12:02 AM
08/04/18 12:02 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Re: BLOCK CLEARANCING w/bryant 4.375" crank and stock HEMI rods [Re: domingo] #2531373
08/04/18 03:17 AM
08/04/18 03:17 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Old siamesed cummings block That was built by Vignogna Racing over 10 years ago.This is a 4.5 Bryant.Could still use the internal pick up but I used a 2 line Milodon.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: BLOCK CLEARANCING w/bryant 4.375" crank and stock HEMI rods [Re: hemi-itis] #2531535
08/04/18 04:08 PM
08/04/18 04:08 PM
Are the rods stock Mopar size or BB Chevy size?
Re: BLOCK CLEARANCING w/bryant 4.375" crank and stock HEMI rods [Re: domingo] #2531578
08/04/18 06:49 PM
08/04/18 06:49 PM
hemi-itis Offline
hemi-itis  Offline
BBC at that time.
