Re: BLOCK CLEARANCING w/bryant 4.375" crank and stock HEMI rods
[Re: domingo]
#2408079
11/24/17 12:15 AM
11/24/17 12:15 AM
Posts: 43,096 Bend,OR USA
Cab_Burge
[Re: domingo]
#2531287
08/03/18 11:56 PM
08/03/18 11:56 PM
Posts: 7,475 Minnesota
Hemi_Joel
Minnesota
THanks for the update, that's good info.
BTW, the blocks with that sticker that says don't bore over 4.34, often can be bored to 4.5". YOu need to sonic test, and you might have to move a cylinder or 2 over toward the thick side to maintain sufficient wall thickness.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: domingo]
#2531290
08/04/18 12:02 AM
08/04/18 12:02 AM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
[Re: domingo]
#2531373
08/04/18 03:17 AM
08/04/18 03:17 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Old siamesed cummings block That was built by Vignogna Racing over 10 years ago.This is a 4.5 Bryant.Could still use the internal pick up but I used a 2 line Milodon.
[Re: hemi-itis]
#2531535
08/04/18 04:08 PM
08/04/18 04:08 PM
Cab_Burge
Old siamesed cummings block That was built by Vignogna Racing over 10 years ago.This is a 4.5 Bryant.Could still use the internal pick up but I used a 2 line Milodon. Are the rods stock Mopar size or BB Chevy size?
